Old 09-04-2008, 05:34 PM   #1
dubdeuce80
dubdeuce80's Avatar
67-72 vs 73-87 lower control arms
are they any different? i know that the crossmembers are interchangeable, but are the lca's interchangeable? i bought some lower bag brackets that were said to be made for 67-87 c10's, but when i got them, they didn't line up at all on my control arms, they were short about 1". here is the ebay link: http://cgi.ebay.com/ebaymotors/ws/eB...m=330264835054
dubdeuce80 is offline   Reply With Quote
Old 09-04-2008, 06:13 PM   #2
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Re: 67-72 vs 73-87 lower control arms
I would think they would work. You should find out soon cuz the guy you bought them from frequents this forum.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 09-04-2008, 06:28 PM   #3
hotrodhomi
hotrodhomi's Avatar
I'm curious as to why you would use a plate instead of a cup?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 09-04-2008, 09:28 PM   #4
scotts62
One day...
scotts62's Avatar
Either or, they are similar concept just to keep the bag from rubbing. I would use the plate verses the cup myself, it looks cleaner and bolts to the control arm. But thats just my opinion
Scott
93 crew cab build
Project 62
Old 09-04-2008, 09:56 PM   #5
jlaird
jlaird's Avatar
hey dubdeuce80,
I'm who you bought those plates from. I'm also curious as why they didn't fit. You are the first I've run into this issue with. Whatever I can do to help just let me know.
josh
jlaird is offline   Reply With Quote
Old 09-04-2008, 09:56 PM   #6
bagged69c10
There has been lots of talk about that subject. The plate wont let it go as low. So Ive heard. Other than that theres nothing wrong with it.
1965 c-10 long bed
1993 Sierra x-cab
Old 09-04-2008, 10:12 PM   #7
jlaird
jlaird's Avatar
only a .25" difference from the lowest you can go with a cup without rubbing.
Old 09-04-2008, 10:32 PM   #8
scotts62
One day...
scotts62's Avatar
Yea knew it wasnt much, depending how my truck sets i may use 8'' pipe and modify lower arm to get the stance i want
Scott
93 crew cab build
Project 62
Old 09-04-2008, 10:37 PM   #9
jlaird
jlaird's Avatar
i've got some pictures in my build thread of modified lowered arms(cut pocket for bag) if you're interested
Old 09-05-2008, 06:12 PM   #10
scotts62
One day...
scotts62's Avatar
Yea man definatly, Thanks
Scott
93 crew cab build
Project 62
Old 09-05-2008, 09:46 AM   #11
Anthony Fremont
Anthony Fremont's Avatar
Not to hijack, but will these plates work with a '66?
'66 GMC Custom Fenderside LWB
'90 IROC - L98
'97 1200C Sportster
Anthony Fremont is offline   Reply With Quote
Old 09-05-2008, 11:22 AM   #12
jlaird
jlaird's Avatar
I'm not 100% sure. I've had people with that year range purchase them, saying if they don't work, they could return them. Never heard back...
Old 09-04-2008, 11:27 PM   #13
dubdeuce80
dubdeuce80's Avatar
hey dubdeuce80,
josh
cool, thanks for the plates and awesome customer service. here are some pictures of them with the sway bar holes lined up. hopefully i don't have 3/4 ton lcas or something (yes i know they are extremely rusty, they've sat through quite a few thunderstorms, but they will be POR15'd along with new drilled/slotted rotors soon!)
this sides fine...
but not so much on this side
i'll be doing some heavy modifications to the crossmember anyways, so i'll be raising where the upper plate mounts while i'm at it, similar to the red rocker i believe it was
Old 09-05-2008, 07:18 AM   #14
jlaird
jlaird's Avatar
hmmm, somthing looks strange, but can't really tell by the angle of those pics. That indentation in the plates should be where the shock mount is. They should be positioned like this pic.
Old 09-05-2008, 08:22 AM   #15
joe231
joe231's Avatar
can you get a pic with out the plate on your lower arms?
I also noticed jlaird has a pair of lower arms and plates for sale on ebay,
maybe you guys could work out a swap if your arms won't work.
here is a LINKY
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 09-05-2008, 08:35 AM   #16
LowSmoothCool
Jon@AirRideTech
LowSmoothCool's Avatar
the control arms are the same from 63-87 only thing that changed are the ball joints. As for plate vs cup on our standard cool ride we use a lower cup style bracket and on our tubular arms we use a flat plate....
LowSmoothCool is offline   Reply With Quote
Old 09-05-2008, 09:40 AM   #17
joe231
joe231's Avatar
if you look at the pics something is different.............
CHEVY ONLY
Old 09-05-2008, 07:58 PM   #18
SCOTI
SCOTI's Avatar
Correction . . ..... BJ's & bushing style/mount.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-09-2008, 07:28 PM   #19
dubdeuce80
dubdeuce80's Avatar
well since we never did figure out what the problem was, i decided to pick up some '69 lcas...except it kinda came with the rest of the truck
i swapped out the suspension that was in it (6 lug) for my old one. i'm gonna clean up the lca's from this '69 and use those since the plates i bought work with them, gonna be fun
Old 09-05-2008, 12:37 PM   #20
panhandler62
Java Mechanic
panhandler62's Avatar
Your lower arms do look slightly different, but that could just be the pictures.
I have a set of 3/4 ton control arms off an 84. When I get home I will have a look at them and see if that clears anything up.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 09-05-2008, 01:07 PM   #21
dubdeuce80
dubdeuce80's Avatar
alright here are a few more pics...
lined up via sway bar holes:
lined up via the edge next to the shock mount:
lined up via the edges:
and the gap left underneath:
Old 09-05-2008, 05:53 PM   #22
aggie91
I'm just glad to be here!
aggie91's Avatar
dubdeuce80 - Do you know the exact year of the LCA's that you have??
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-09-2008, 09:25 PM   #23
joe231
joe231's Avatar
love those wheels!
CHEVY ONLY
Old 09-11-2008, 04:31 PM   #24
rddiaz
rddiaz's Avatar
Whatever happened to this problem with the plates? did it ever get resolved?I got an 86 SWB and I have the same problem, plates just do not fit. I wish I would of known of this before I bought them, but it does say on ebay it will fit 67-87 LCA's? I was hoping I would get done this weekend!!!
GROUND ZERO IS R LIMIT
rddiaz is offline   Reply With Quote
Old 09-11-2008, 04:38 PM   #25
dubdeuce80
dubdeuce80's Avatar
like i said in the above post, i picked up a '69, and both the upper and lowers are completely different than the ones on my '80. once i get the balljoints removed (probably sometime this weekend) i will take a side by side picture of both lowers
