![]() Join Date: Nov 2008
Anyone running the Cable X?
How do you like it? Any pros or cons? Is it accurate/reliable? Thanks in advance for any info.
Next project: 1970 K10
Re: Anyone running the Cable X?
I'm not aware of anyone on here currently using one.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#3 | |
Ray Last edited by raycow; 08-12-2010 at 10:00 AM. |
GM ONLY BABY!!!
I am planning on aftermarket electric speedo as well, more affordable.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
![]() Join Date: Nov 2007
I have a CableX on my 6.0L swap but I haven't got it to work yet, although it works on the bench if you send it a signal.
So I hooked it up to a VSS signal wire coming from the ECM, doesn't run. Now I am thinking that you have to provide a voltage to that VSS wire to get it to pulse. So I am going to experiment with that and hope I don't blow the ECM. I think the CableX was designed to read the speed sensor directly maybe. I guess I will give them a call. I have got so many things on my punch list that one hasn't made it to the top yet. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
#6 | |||
Thanks for the reply.
I got my CableX working today with the VSS signal wire from the ECM.
The problem was that the signal from the ECM is much lower frequency than what comes from the speed sensor itself. So you have to set the pulses per mile much lower. (So if you use the pulse per mile from the sensor in the CableX the speed is too low to run the motor) I am using an E40 ECM and the speedometer is accurate when I set the pulses per mile at 1000. (I understand that mechanical speedometers are standardized to 1000 turns per mile). So evidently the ECM is putting out a 1000 pulse per mile signal. CableX seems to work fine with that. Interesting that they make no mention of this in the CableX instructions but the CableX tables allow you to set very low pulses per mile. TR
#8 | |
I beleive Shon is running a cable-x box with his LSX swap.
I am running the Cable X box. I like it.
If you need one I will ship a new one for $300.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
