The usual tire size question......Please help an idiot out.....
Please help me out on this guys. Just picked up a set of 17x9" wheels with a 6 inch offset. Hoping to run them on my '79 2 wheel drive with no drop. May drop it later but will be a 2" max. What would be the best tire size for me to run. Looking at possibly going with a 275/55/17 but I'm not sure. What is everyones opinion on this. Thanks.....
Justin
1979 Silverado 305 Factory A/C..... 2006 Silverado 4x4 Crew Cab..... |
Cruzzzn' Vet
Re: The usual tire size question......Please help an idiot out.....
Take your pick
![]() http://www.tirerack.com/tires/sizes/...sp?diameter=17 Use this calculator to see how the tires stack up against each other. http://www.miata.net/garage/tirecalc.html Last edited by Malo83; 01-03-2011 at 06:17 PM. |
Badass
315/35/17
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() Last edited by 3r!c84; 01-04-2011 at 12:10 AM. |
275/60/17 Goodyear on a 17x9.5 wheel with 5.5 inches of backspace. It is lowered 5 inches in the rear .
Frank
Born and proudly residing in a Red State ! |
#5 | |
Frank, would you have room to go another .500" toward the center of the truck? I know my 74 was very close (too close) @ 5.5"bs. I don't think 6"bs would work w/o spacers. Same on the front.... I had 8's w/5.25"bs which required a fairly healthy shave of the lower a-arm lip. 6"bs would require the same, & then some.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-04-2011 at 01:57 AM. |
#6 | |
Frank
I run 315/35/17 in the rear and 275/45/17 in the front. I have shaved a small amount from the lower a arms and installed wheel spacers. They have never rubbed and ride good.
America is all about speed, hot nasty bad ass speed ![]() |
275/55/17x9..........225/55/17x9.. in front with a 4.6 drop.c notch,flip kit...no issues.
" Never look up a dead dogs butt." ![]() |
List your back-spacing guys.....
Badass
i realy dont know mine. i got them used. no fitment problem. the back could use a 1/2 spacer. it rubs the inner wells on hard turns. im going to get skinner tires next time around to fix that problem
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
