Old 01-03-2011, 06:02 PM   #1
same_me
same_me's Avatar
The usual tire size question......Please help an idiot out.....
Please help me out on this guys. Just picked up a set of 17x9" wheels with a 6 inch offset. Hoping to run them on my '79 2 wheel drive with no drop. May drop it later but will be a 2" max. What would be the best tire size for me to run. Looking at possibly going with a 275/55/17 but I'm not sure. What is everyones opinion on this. Thanks.....
Justin
1979 Silverado 305 Factory A/C.....
2006 Silverado 4x4 Crew Cab.....
same_me is offline   Reply With Quote
Old 01-03-2011, 06:11 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: The usual tire size question......Please help an idiot out.....
Take your pick
http://www.tirerack.com/tires/sizes/...sp?diameter=17
Use this calculator to see how the tires stack up against each other.
http://www.miata.net/garage/tirecalc.html
Malo83 is offline   Reply With Quote
Old 01-04-2011, 12:10 AM   #3
3r!c84
Badass
3r!c84's Avatar
315/35/17 but hey thats me (;
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-04-2011, 12:56 AM   #4
f.monroe
f.monroe's Avatar
275/60/17 Goodyear on a 17x9.5 wheel with 5.5 inches of backspace. It is lowered 5 inches in the rear .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 01-04-2011, 01:57 AM   #5
SCOTI
SCOTI's Avatar
Frank
More importantly....
Frank, would you have room to go another .500" toward the center of the truck? I know my 74 was very close (too close) @ 5.5"bs. I don't think 6"bs would work w/o spacers.
Same on the front.... I had 8's w/5.25"bs which required a fairly healthy shave of the lower a-arm lip. 6"bs would require the same, & then some.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-04-2011, 11:38 AM   #6
blazer2007
could you post a side shot of your truck, thanks
blazer2007 is offline   Reply With Quote
Old 01-04-2011, 02:22 PM   #7
3r!c84
Badass
3r!c84's Avatar
-00 Saturn 5spd
1/4:13:90
Old 01-04-2011, 02:32 PM   #8
JuicyJ
JuicyJ's Avatar
I run 315/35/17 in the rear and 275/45/17 in the front. I have shaved a small amount from the lower a arms and installed wheel spacers. They have never rubbed and ride good.
America is all about speed, hot nasty bad ass speed
JuicyJ is offline   Reply With Quote
Old 01-04-2011, 04:49 PM   #9
boatpuller
boatpuller's Avatar
275/55/17x9..........225/55/17x9.. in front with a 4.6 drop.c notch,flip kit...no issues.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 01-04-2011, 04:51 PM   #10
SCOTI
SCOTI's Avatar
List your back-spacing guys.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-04-2011, 05:27 PM   #11
same_me
same_me's Avatar
Please.....
Old 01-04-2011, 08:54 PM   #12
f.monroe
f.monroe's Avatar
You are right about the rear . I would never go any more than 5.5 backspace in the rear unless I was going to use a spacer . The fronts clear the a-arms fine but I only use 2.5 Western Chassis spindles for that reason. Once you go to 3 inch spindles you have clearance issues.
Frank
Old 01-04-2011, 10:45 PM   #13
3r!c84
Badass
3r!c84's Avatar
i realy dont know mine. i got them used. no fitment problem. the back could use a 1/2 spacer. it rubs the inner wells on hard turns. im going to get skinner tires next time around to fix that problem
-00 Saturn 5spd
1/4:13:90
