03-13-2012, 02:38 PM | #1 |
66 front suspension Q's
ok so the daughters ride will be home soon...want to change it from 3/4 ton to 1/2 ton. rearend is easy... but what should i look for for the front. 5 or 6 lug doesn't matter, but i already have a 6 lug 1/2 ton rear just waiting so i'll probably stick with this route. i would like to do something from '73 and up for the front due to the rubber bushings and such. can i swap a complete front suspension with out a ton of work? i know there will be some stuff to do, but i'm talking like when i put the camaro sub frame under my '59. (kinda major surgery to me.) any thoughts or ideas? i was kinda hoping to find something at our local u-pullit yard. (at least the crossmember and arms an such)... thanks guys.
'59 SWB (the money pit) Camaro clip/5.3 LM7/700r4/10bolt rear/bagged/and some mild mods here and there. '93 Jeep Cherokee with some stuff. (the toy) '06 Silverado 2500HD (daily driver) '12 Equinox (wifes ride) '66 Chevy LWB (daughters ride) |
03-13-2012, 04:25 PM | #2 | |
Re: 66 front suspension Q's
To match the 6-lug bolt pattern of the rear, just use aftermarket 6-lug disc brake rotors available here from supporting board vendors. They're a direct swap for the 5-lug rotors.
03-13-2012, 10:37 PM | #3 |
Thanks SCOTI. Just swapping A arms and spindles and such is nice to know.I think I'll spend a couple days Google surfing. And here also of coarse!
