Old 03-13-2012, 02:38 PM   #1
59weasel
66 front suspension Q's
ok so the daughters ride will be home soon...want to change it from 3/4 ton to 1/2 ton. rearend is easy... but what should i look for for the front. 5 or 6 lug doesn't matter, but i already have a 6 lug 1/2 ton rear just waiting so i'll probably stick with this route. i would like to do something from '73 and up for the front due to the rubber bushings and such. can i swap a complete front suspension with out a ton of work? i know there will be some stuff to do, but i'm talking like when i put the camaro sub frame under my '59. (kinda major surgery to me.) any thoughts or ideas? i was kinda hoping to find something at our local u-pullit yard. (at least the crossmember and arms an such)... thanks guys.
'59 SWB (the money pit)
Camaro clip/5.3 LM7/700r4/10bolt rear/bagged/and some mild mods here and there.
'93 Jeep Cherokee with some stuff. (the toy)
'06 Silverado 2500HD (daily driver)
'12 Equinox (wifes ride)
'66 Chevy LWB (daughters ride)
59weasel is offline   Reply With Quote
Old 03-13-2012, 04:25 PM   #2
SCOTI
SCOTI's Avatar
Re: 66 front suspension Q's
The 73-87 front suspension package will interchange/swap over to your 66 w/minimal issues. You can also swap just the suspension pieces to your existing 66 x-member.
To match the 6-lug bolt pattern of the rear, just use aftermarket 6-lug disc brake rotors available here from supporting board vendors. They're a direct swap for the 5-lug rotors.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-13-2012, 10:37 PM   #3
59weasel
Thanks SCOTI. Just swapping A arms and spindles and such is nice to know.I think I'll spend a couple days Google surfing. And here also of coarse!
