![]() Join Date: Aug 2008
Original Stepside Truck Bed Hardware
What was the original finish of the hardware use to attach the tailights? Bed to fender bolts were painted body color right? These were panhead screws? Seems trivial to some I'm sure, but I like to have original style hardware whenever possible. Pics are good, details are good.
Nothing better than an old truck... 76 C-10 Silverado 92 Silverado Z71 |
Crazy
Re: Original Stepside Truck Bed Hardware
If I can recall correctly the tail light bracket bolts were hex heads painted to match the body.
The bed to fender attachment was pan head Phillips screws, also painted to match the body.
77 SB Stepside in a bunch of pieces scattered around the garage. |
#3 | |
This is correct. drmiller - be careful when restoring the taillamp brackets and fasteners. They originally had star washers, designed to gouge the paint and provide the electrical ground for the tail lamp and turn signal. If you do "too good" a job in this area then you will lose the ground and your turn signals will not work correctly. Or - you can add an additional ground wire, snaked from the bulb socket through the wire harness and attached to the frame. This was a suitable (and classy) fix. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Thanks guys,
The truck came with an assortment of stainless steel hex head and Ford body bolts in the bed area. Getting things in correct order can be a slow process. Thanks for the star washer tip Keith. They are used on the lamp to body bracket's only right? Were the panheads for the fender to bed used with washers?
Crazy
There is a washer on the fender bolts. But its basically the same diameter as the head of the screw. When I was taking mine all apart I was trying to decide why it was really there.
I ran the extra ground wire to mine myself. If I can find my old box of bolts from my resto, I'll take a look for you and get you a pic. I replaced every bolt in the whole truck pretty much with stainless, so they should be somewhere in my garage.
Thanks tgh117,
I am still trying to figure out where to buy those fender screws. There are many vendors who carry them. Just looking for the best deal. That washer for the fender a flat type?
Crazy
yea just a flat washer. I still haven't come across the box that has those in it yet, but I will keep my eye out. seems like a I have a few too many boxes of parts left over from my rebuild/resto...
I know they have them at Mar-K for like 25 ish bucks for the kit. Good luck with your search.
Flat washers okay. I have order some fender bolts from Classic parts of America- .60 each. I will go to the local build box store for the washers.Thanks for the info.
I have 2 6' stepside and 1 8' box and none had washers on the Philip head fender to bedside bolts.
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
Well that mix's things up a bit. I have just placed my order for screws, maybe this will sort out before they get here
