Old 07-31-2013, 05:43 PM   #1
drmiller1
Original Stepside Truck Bed Hardware
What was the original finish of the hardware use to attach the tailights? Bed to fender bolts were painted body color right? These were panhead screws? Seems trivial to some I'm sure, but I like to have original style hardware whenever possible. Pics are good, details are good.
Nothing better than an old truck...
76 C-10 Silverado
92 Silverado Z71
drmiller1 is offline   Reply With Quote
Old 08-01-2013, 10:42 AM   #2
tgh117
Crazy
tgh117's Avatar
Re: Original Stepside Truck Bed Hardware
If I can recall correctly the tail light bracket bolts were hex heads painted to match the body.
The bed to fender attachment was pan head Phillips screws, also painted to match the body.
77 SB Stepside in a bunch of pieces scattered around the garage.
tgh117 is offline   Reply With Quote
Old 08-01-2013, 11:12 AM   #3
Keith Seymore
Keith Seymore's Avatar
This is correct.
drmiller - be careful when restoring the taillamp brackets and fasteners. They originally had star washers, designed to gouge the paint and provide the electrical ground for the tail lamp and turn signal. If you do "too good" a job in this area then you will lose the ground and your turn signals will not work correctly.
Or - you can add an additional ground wire, snaked from the bulb socket through the wire harness and attached to the frame. This was a suitable (and classy) fix.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-01-2013, 05:12 PM   #4
drmiller1
Thanks guys,
The truck came with an assortment of stainless steel hex head and Ford body bolts in the bed area. Getting things in correct order can be a slow process. Thanks for the star washer tip Keith. They are used on the lamp to body bracket's only right? Were the panheads for the fender to bed used with washers?
76 C-10 Silverado
92 Silverado Z71
Old 08-02-2013, 03:31 PM   #5
tgh117
Crazy
tgh117's Avatar
There is a washer on the fender bolts. But its basically the same diameter as the head of the screw. When I was taking mine all apart I was trying to decide why it was really there.
I ran the extra ground wire to mine myself. If I can find my old box of bolts from my resto, I'll take a look for you and get you a pic.
I replaced every bolt in the whole truck pretty much with stainless, so they should be somewhere in my garage.
Old 08-02-2013, 06:32 PM   #6
drmiller1
Thanks tgh117,
I am still trying to figure out where to buy those fender screws. There are many vendors who carry them. Just looking for the best deal. That washer for the fender a flat type?
76 C-10 Silverado
92 Silverado Z71
Old 08-07-2013, 08:24 AM   #7
tgh117
Crazy
tgh117's Avatar
yea just a flat washer. I still haven't come across the box that has those in it yet, but I will keep my eye out. seems like a I have a few too many boxes of parts left over from my rebuild/resto...
I know they have them at Mar-K for like 25 ish bucks for the kit.
Good luck with your search.
Old 08-07-2013, 08:57 AM   #8
drmiller1
Flat washers okay. I have order some fender bolts from Classic parts of America- .60 each. I will go to the local build box store for the washers.Thanks for the info.
76 C-10 Silverado
92 Silverado Z71
Old 08-07-2013, 04:41 PM   #9
walkerb
walkerb's Avatar
I have 2 6' stepside and 1 8' box and none had washers on the Philip head fender to bedside bolts.
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 08-07-2013, 04:59 PM   #10
drmiller1
Well that mix's things up a bit. I have just placed my order for screws, maybe this will sort out before they get here. I did notice no washers mention or shown on the website.
76 C-10 Silverado
92 Silverado Z71
