07-09-2016, 11:38 AM | #1 |
1981-87 quarts clock complete!
I've tested this clock and it works great-includes the plastic lense grommet and the correct uncut leads as well as the metal clip that also secures the white door jamb wire too! This is a complete working clock setup from an 83 Silverado originally. $55 shipped for what you see here! Thanks!
07-10-2016, 05:24 PM | #2 |
Re: 1981-87 quarts clock complete!
(2) of these are now available!
07-15-2016, 07:31 PM | #3 |
id like one
07-15-2016, 11:29 PM | #4 |
07-17-2016, 04:10 AM | #5 |
Hello.
If it will fit my 78, I will take the second one Thanks, Mike
*1978 C10 Cheyenne Big 10. Matching Numbers Block, 355/Turbo 350. 12 Bolt 342 Posi, 186 Double Hump Heads *1972 Chevelle. 406-6" Rods/Turbo 350 TCI kit, 12 Bolt narrowed, 456 Full Spool, C-Clip Eliminator, 8pt Roll Cage *1979 C10 Scottsdale. Matching Numbers, all original, 350/Turbo 350. 12 Bolt 308 |
07-17-2016, 08:58 AM | #6 |
It will work in your 78 if you have a clock option vs a brake light but, the adjustment knob is in a different spot so you would need an 81-up plastic lense with the correct hole or you can drill one. Also, the 81-up font style differed from 78 slightly.
07-15-2016, 07:51 PM | #7 |
Ok...PM on the way!
07-17-2016, 09:23 AM | #8 |
Sent you a PM.
I will take the clock, the plastic lense grommet and the correct uncut leads! Will make it work Thanks Mike
07-17-2016, 09:47 AM | #9 |
2nd clock SOLD to Mike!!
07-17-2016, 11:35 AM | #10 |
Thank you.
Payment sent. I'll look for it in the mail soon.
