1981-87 quarts clock complete!
I've tested this clock and it works great-includes the plastic lense grommet and the correct uncut leads as well as the metal clip that also secures the white door jamb wire too! This is a complete working clock setup from an 83 Silverado originally. $55 shipped for what you see here! Thanks!
Re: 1981-87 quarts clock complete!
(2) of these are now available!
id like one
Ok...PM on the way!
![]() Join Date: Mar 2016
Hello.
If it will fit my 78, I will take the second one Thanks, Mike
*1978 C10 Cheyenne Big 10. Matching Numbers Block, 355/Turbo 350. 12 Bolt 342 Posi, 186 Double Hump Heads *1972 Chevelle. 406-6" Rods/Turbo 350 TCI kit, 12 Bolt narrowed, 456 Full Spool, C-Clip Eliminator, 8pt Roll Cage *1979 C10 Scottsdale. Matching Numbers, all original, 350/Turbo 350. 12 Bolt 308 |
It will work in your 78 if you have a clock option vs a brake light but, the adjustment knob is in a different spot so you would need an 81-up plastic lense with the correct hole or you can drill one. Also, the 81-up font style differed from 78 slightly.
Sent you a PM.
I will take the clock, the plastic lense grommet and the correct uncut leads! Will make it work Thanks Mike
2nd clock SOLD to Mike!!
Thank you.
Payment sent. I'll look for it in the mail soon.
