Spark plug wires
What are you using for plug wires on these trucks with a pointless distributor off a newer truck? I bought wires for a 77 truck, but they don't work that well. The distributor cap is too close to the firewall for some of the wires to point in the right direction. That makes the wires too short to run around the back and sides of the engine like they are supposed to. Likewise, the 90 degree boot at the plugs won't let the wires go up and over the manifold, but the wires are too short to point the boots downward. It's a carbuerated 350 in a '65 c20. The distributor is from a '77 or so.
Thanks. Last edited by Morgan in AR; 12-13-2019 at 04:39 PM. Reason: Forgot info |
#2 | |
Re: Spark plug wires
Moderator
![]() ![]() Join Date: Aug 2011
That's what I like doing. You can make each wire length perfect for you.
![]() ![]() ![]() Join Date: Jan 2018
I used plug wires that fit a 74 corvette. They fit great with my stock ram horns and are the necessary wire size for the HEI
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#5 | |
![]() Join Date: Sep 2006
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
I ordered 2 sets of ACDelco 628M wires and used the longest wires (I DETEST making my own wires). They were cheap enough (about $25/set that it wasn't too painful). I toss a couple of the medium length wires into the toolbox in case I burn a wire, etc out on the road.
If you look on Summit Racing, some sets specify under manifold, over manifold, over valve cover.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
check out dui,davis unified ignition
there dizzys and wires are very nice |
