Old 12-13-2019, 04:36 PM   #1
Morgan in AR
Spark plug wires
What are you using for plug wires on these trucks with a pointless distributor off a newer truck? I bought wires for a 77 truck, but they don't work that well. The distributor cap is too close to the firewall for some of the wires to point in the right direction. That makes the wires too short to run around the back and sides of the engine like they are supposed to. Likewise, the 90 degree boot at the plugs won't let the wires go up and over the manifold, but the wires are too short to point the boots downward. It's a carbuerated 350 in a '65 c20. The distributor is from a '77 or so.
Thanks.
Morgan in AR is offline   Reply With Quote
Old 12-13-2019, 05:10 PM   #2
forestb
forestb's Avatar
Re: Spark plug wires
Thanks.
I made a set of my own for my 350. Taylormade Brand
forestb is offline   Reply With Quote
Old 12-13-2019, 05:33 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
I used plug wires that fit a 74 corvette. They fit great with my stock ram horns and are the necessary wire size for the HEI
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 12-14-2019, 02:10 PM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
same here
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-14-2019, 04:01 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
That's what I like doing. You can make each wire length perfect for you.
Old 12-15-2019, 09:08 PM   #6
Bushman66
I ordered 2 sets of ACDelco 628M wires and used the longest wires (I DETEST making my own wires). They were cheap enough (about $25/set that it wasn't too painful). I toss a couple of the medium length wires into the toolbox in case I burn a wire, etc out on the road.
Bushman66 is offline   Reply With Quote
Old 12-16-2019, 07:57 AM   #7
rpmerf
rpmerf's Avatar
If you look on Summit Racing, some sets specify under manifold, over manifold, over valve cover.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 12-16-2019, 07:26 PM   #8
oldtrux
oldtrux's Avatar
check out dui,davis unified ignition
there dizzys and wires are very nice
oldtrux is offline   Reply With Quote
