Old 03-23-2020, 03:38 PM   #1
67see10
67see10's Avatar
60-63 & 64-66 Frames Interchangeable?
I recently came across a 65 GMC Big Back Window leaf spring truck that I brought. Recently a 62 shortbed trailing arm chassis went up for sell. When doing some research, I determined that the frames are different but could not find a definite on whether I can throw the shortbed frame under the 65 body.
67see10 is offline   Reply With Quote
Old 03-23-2020, 06:37 PM   #2
LVPhotos
LVPhotos's Avatar
Re: 60-63 & 64-66 Frames Interchangeable?
The body mounts are different, the frame on 62 is X with torsion bars and wider, the 65 is ladder. All is possible but most look in different directions.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 03-23-2020, 09:45 PM   #3
Captainfab
60-66 Nut
The '60-'62 frames are the same and the '63-'66 frames are the same. You can mount your '65 body onto the '62 frame but the front cab mounts are farther apart and the bed mounts are wider side to side on the '62 frame. What is your reason for wanting the '62 frame/running gear?
Old 03-24-2020, 10:23 AM   #4
67see10
67see10's Avatar
I was planning a swb conversion and figured that a chassis swap would be easier if there were the same.
Old 03-24-2020, 01:03 PM   #5
jayoldschool
Moderator
Without wanting to offend anyone... I think the 64-66 frame/suspension setup is superior, and if you are going to go through the effort of a swap, you should hold out for the later frame. Speaking of that, you can use a 67 up frame, too, IIRC...
jayoldschool is offline   Reply With Quote
Old 03-24-2020, 03:06 PM   #6
67see10
67see10's Avatar
thanks for the info
Old 03-24-2020, 09:33 PM   #7
Captainfab
60-66 Nut
IMO it would be easier to shorten your long wheelbase frame than to change to the earlier frame. And I don't just say that because I don't care for the '60-'62 frames.
Old 03-24-2020, 11:36 PM   #8
67see10
67see10's Avatar
Yeah, thats what I concluded. Thanks for the help
