60-66 Nut
Re: 60-63 & 64-66 Frames Interchangeable?
The '60-'62 frames are the same and the '63-'66 frames are the same. You can mount your '65 body onto the '62 frame but the front cab mounts are farther apart and the bed mounts are wider side to side on the '62 frame. What is your reason for wanting the '62 frame/running gear?
| Bookmarks |
