Need help for v belts part numbers
happy new year to all
need help for v belts part numbers for my gmc k2500 1972 ( napa or good year ) vin number is : Tke242z513060 big thanks
MY Facebook ( saad_alhajri ) on Instagram
![]() Join Date: Mar 2003
Re: Need help for v belts part numbers
Any numbers on the existing belts?
I got lost on the way Alternator belt But the other belts I have a number .
![]() ![]() Join Date: Jul 2003
GM belt part numbers. Usually located on Ebay.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
I just want to know the part number napa or good year Alternator belt .
A smart man would know to cross reference to get the right belt....
#7 | |
A smart man should know that in my country these belts are not available so he should order them in the correct size from the Internet
#8 | |
![]() Join Date: Jun 2022
I have these in my notes. Chevy, but my layout is the same as yours:
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
This item doesn't fit ( alternator GATES 7525 )
Belt numbers indicate the belt length. So the PS belt shown is 15356 15/32 wide and 35.6 inches long. The 25-7555 is 10mm wide and 55.5'' long ( I don't know what the 7 means) and the alternator belt is usually 52.5 long, but I recently installed an alt upgrade to a 1 wire on a truck and the belt length needed was a little longer and I still had to force it on a little at 53'' long so it took a 15530. Hope that helps. The gates shown before this post shows a 7525 --7/16'' wide and 52.5 long
Maybe you have the 62A alternator, or... :shrug:
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 Last edited by Rust_never_sleeps; 01-01-2025 at 07:06 PM. |
No sir its 63A
I mentioned that because rockauto listed a different belt. Worth a look since they show different options for several combinations of accessories. If you click the info button, it will show belt dimensions
Also agree with the suggestion to measure the path with a rope or tape measure. Belt length is measured at the outside edge of the pulleys.
![]() Join Date: Nov 2018
If worse comes to worse, wrap a rope around it and measure to get a starting point for a belt length.
#15 |
this Alternator who needs a belt .
#16 |
Always on the hunt...
Saad, as an FYI that alternator shown in reply #13 is not the correct model/type for your 72 K2500, if interested in more info and pics on the 71 and prior vs. 72 style alternator subject see the below linked thread post #10, #16 and #20. Happy New Year and good luck in your search, Mel in Oregon
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=855980 .
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our payment account info has been changed as of Jan. 2023. Thanks... |
#17 | |
Very clear. Thank you sir and happy new year
#18 |
As information only the X in the number is for the clogs on the inside of the belt.
it makes no difference on the sizing. They are rated for smaller diameter pulleys and higher HP than the belts with the smooth inner. Either with or with out the X in the umber will function fine. I believe this "X" type of belt was invented after out trucks were made. OEM belts of this era were all smooth on the inside. Cheers |
#19 | |
#20 |
![]() Join Date: Jul 2000
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#21 | |
| Bookmarks |
