Old 11-22-2004, 10:59 PM   #26
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Originally Posted by pound41
Actually found a page in assembly manual giving measurements of the gaps and it talked about how the body mounts are the key
DID IT GIVE A STANDARD MEASUREMENT FOR BODY MOUNT THICKNESS
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-23-2004, 11:11 AM   #27
A few 72's
A few 72's's Avatar
Here's the ones I took last night. (No measurements of mounts)
1st thing I would check to see if the each set of mounts are the same from one side to the other. (Wrong bushing used?) Also if you see one that apears to be smashed may want to check that the tube (item 4 in bolt pic) was used.
2nd would sugest taking a torque wrench to the bolts to see if they are the same. (Could be that one is to tight or never was tight.) Could not find torque for 1st mount, but all others were 15 -24 Ft lbs. Would say front should be the same also.
Also included the one of the door wedges.
3rd add or remove shims...
The one I had to show the front fender to door gap was not clear. Will try to get it later if needed.
Hope these help.
A few 72's is offline   Reply With Quote
Old 11-23-2004, 04:44 PM   #28
pound41
I am not saying they have the measurements I haven't actually looked but LMC very detail I ordered all new bolts and washers etc for my kit that I already had from them
pound41 is offline   Reply With Quote
Old 11-23-2004, 07:27 PM   #29
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
THANKS GUYS, HOWEVER I'M BACK TO PAGE ONE AGAIN , SEE MY POST ON
THE PARTS BOARD, THANKS "AFEW72'S", WISH I'D NOTICED B4 PRIMER WORK.
Old 11-23-2004, 07:38 PM   #30
Gee_Emm
So why do you need new fenders?
Gee_Emm is offline   Reply With Quote
Old 11-23-2004, 08:01 PM   #31
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
BECAUSE I'M BUILDING A 72, AND I DON'T WANT TO USE THE OE ONES
FROM CALI, THEY NEED JUST A LIL BODYWORK TO BE PERFECT AND I
AM TIRED OF SHELLING OUT CASH FOR BODYWORK, TRYING TO SAVE
UP TO GET HER PAINTED IN THE SPRING & I KEEP GOING BACKWARDS.
http://67-72chevytrucks.com/vboard/s....php3?t=128837
Old 11-23-2004, 08:07 PM   #32
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Hey luv you really need to get the 1967-72 chev/gmc truck assembley manual it has helped me out of almost evey tight spot I have gotten myself into..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-23-2004, 10:39 PM   #33
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
SUPPOSED TO BE GETTING ONE FOR CHRISTMAS
