Old 01-18-2011, 04:33 PM   #26
Tmend
Tmend's Avatar
Re: Bolt in steering rack
you got a ballpak price yet
Tmend is offline   Reply With Quote
Old 01-18-2011, 08:26 PM   #27
rob32472
Originally Posted by robnolimit View Post
As luck would have it, we are currently testing a C-10 Rack&Pinion set-up. (67-87) I'll let you know when were done. So far it fits very nice. 2.75 turns lock-to-lock. Full steering to 40 deg (same as stock). .136 deg bump-out in 4" of compression travel, and .166 deg bump-out in 4" of droop. This mod will require some cutting and welding on the crossmember. We are working on the install templates, and machined adjusters for the TRE. --- SOON, VERY SOON.
I am very interested in this upgrade keep me posted!!!!
rob32472 is offline   Reply With Quote
Old 01-18-2011, 11:33 PM   #28
Tmend
Tmend's Avatar
Same here please keep me posted.
Old 01-19-2011, 02:02 PM   #29
robnolimit
robnolimit's Avatar
HAHA, not yey, but I have to guess it'll be less than $3000.00 - a lot less. I'm going to test one on out JT 72, in a couple of weeks. Then I'll get some picts up. Sorry, but I can't let to much out yet, as a lot of our competion uses us for R & D (Rip-off and Duplicate)
robnolimit is offline   Reply With Quote
Old 01-19-2011, 02:48 PM   #30
Tmend
Tmend's Avatar
rip off and duplicate thats funny sh*&t never heard that one befor. but understood just keep us posted im very intredted thanks.
Old 01-19-2011, 03:13 PM   #31
tech@scottshotrods
I don't see any of us vendors on here doing that.... Nate does his thing, we do ours, i dont see cpp doing that soooo post away rob
tech@scottshotrods is offline   Reply With Quote
Old 01-22-2011, 12:08 PM   #32
chapster
chapster's Avatar
Very interesting,
If it is possible to manufacture this kit to be affordable and still make a profit, I think it would sell like crazy!!
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler
1968 Chevy c10 shorty Stepper (Patina LS project)
1967 gmc custom Long Box (Farm Truck Project)
chapster is offline   Reply With Quote
Old 01-22-2011, 01:42 PM   #33
rob32472
Agreed!
Old 01-22-2011, 04:34 PM   #34
michaelnolimit
Active Member
OK guys, it's looking good so far. This kit will include a P/S rack, mounting kit, machined tie rod adjusters, Lower steering U-joint, Drivers side motor mount, lower steering shaft, and probably two cutom fitting for the rack. Now, what do you think is a fair price point. Looks like the kit would be in the 775 range. Not to far off of a complete rebuild of the factory P/S, and our rack kit cuts bumsteer to .192 deg. in 3" travel either side of RH. Well?
michaelnolimit is offline   Reply With Quote
Old 01-22-2011, 05:18 PM   #35
SCOTI
SCOTI's Avatar
Standard app R&P or custom? Not bad pricing either way really.... just better in the 'big picture' if it's not a custom R&P.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-22-2011, 05:44 PM   #36
Tmend
Tmend's Avatar
Let's see so for $775 ill do away with all the steering components tha tke that nice look away and that huge steering box that leaks and look ugly get to keep my stock crossmember that already was disc brakes and keep my bag set up.BUT get the modern feel of a rack and pinion? Well sir you can count me in....
Old 01-22-2011, 10:07 PM   #37
rob32472
Here is a snag for ya what about us ls motor transplant guys I am using ece mounts....... 775.00 is a good price point for the rack..... I am in if I can get the motor mount situation solved!
Old 01-23-2011, 07:46 PM   #38
chapster
chapster's Avatar
I am curious on the accommodation of the lsx swaps with different styles of engine perches myself?
Old 02-03-2011, 05:25 PM   #39
rob32472
Any updates?
Old 02-03-2011, 07:21 PM   #40
tubbedII
needs more $$$
tubbedII's Avatar
Will the kit work with a sectioned crossmember?
I can't see myself spending the 775 for a R&P any time soon, but if it works with a a sectioned crossmember, it sounds like a cheaper way to have good steering and be able to lay frame.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 02-03-2011, 09:15 PM   #41
robnolimit
robnolimit's Avatar
still working on it. As a plus, the guys at Painless are building a C-10 for the Power tour, and they made me promise to have one for them. So, now I have a deadline, to help spur me along.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
Old 02-10-2011, 11:28 PM   #42
chermik1999
Hey Rob,
No disrespect to Nate as he's helped me out a bit and a super fellow by email, but I have CPP upper and lower tube arms, bags etc already. I'm trying to save a bit on an expensive build that has just started(or my wife will shooooot me!). Would your new drop member be compatible with other control arms?
chermik1999 is offline   Reply With Quote
Old 02-10-2011, 11:37 PM   #43
robnolimit
robnolimit's Avatar
We're not planning on competing with Porter's Dropmember. What we have in the works is a Power Rack and Pinion upgrade to the stock crossmember. As it will be a tunabe install, it should work fine with ANY aftermarket set of arms. - regardless of any wheel placement or caster changes from the arms. - - - Buy your wife a nice Valentines gift. Happy Wife = Happy Life.
Old 02-10-2011, 11:51 PM   #44
chermik1999
I here ya....you both sound like you have great integrity.....good stuff. I own a business here as well and do the same. U 2 are awesome...keep it up....you'll go along way...you too Rob.
OK...so either a change all or try the R/P with my existing K-member.
Super.....I'll watch and decide. And I will.....but she still loves me????......I hope...LOL
thanks
Old 02-11-2011, 04:08 PM   #45
Mike J
vw guy & now c-10 guy
Mike J's Avatar
ok, I have 2 questions about this set-up. Should be fine with a 6-cyl application right? and manual rack should work just fine as well, right? Thanks! $775 seems fair
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 02-11-2011, 04:34 PM   #46
robnolimit
robnolimit's Avatar
Hmm, never thought of that one. 6 cyl. is no problem, but we will not be offering a manual rack option - sorry. If we did, I don't think you would be happy with us, and it would end up a loose-loose. We try to avoid that as much as we can. It would be easy enough to put a p/s pump on the 6 cyl
Old 02-11-2011, 04:45 PM   #47
dwcsr
Hollister Road Co.
dwcsr's Avatar
If anyones interested I did a power rack on a C10 about 8 years ago.
heres a link to it. It cost about $300 to do. You will need some good fab skills.
http://www.thehollisterroadcompany.com/rackpinion.html
Old 02-11-2011, 09:57 PM   #48
Tmend
Tmend's Avatar
That link looks like lots of work and the outcome doesn't look that great. To many ifs. Im gonna wait it out till robs done then make a choice from there..thanks for the link tho.
Old 02-12-2011, 10:33 AM   #49
dwcsr
Hollister Road Co.
dwcsr's Avatar
Its does have some ugly on it, But it was a first attempt and has been refined greatly since then. The out come was to have a truck suspension under a truck that was driven daily and not have to turn the wheel 5 turns from lock to lock. As far as looks unless I planned on having the guys over to stare at my rack for the afternoon and not the gril next stores rack then I would have done a C5 or something
Old 02-12-2011, 12:24 PM   #50
lolife99
67-72 parts collector,…
lolife99's Avatar
I'm not so sure about that.
250 and 292 P/S brackets and pulleys are getting harder and harder to come by.
Keith
Convert to disc brakes.
