Old 12-06-2011, 06:24 AM   #1
Hazieview
Building Dreams out of Dimes!
Unused Heater core for Transmission cooler???
Hey guys I have a pretty new heater core laying around that was only used for a short time before being removed. I was thinking of using it as a transmission cooler what do yall think?
I also have a small AC condensor I thought about using...
Just a thought. What do you think?
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 12-06-2011, 09:24 AM   #2
J Knight
J Knight's Avatar
Re: Unused Heater core for Transmission cooler???
I would think a mod like that will either cool to much or not enough. Not a good idea IMO.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 12-06-2011, 09:32 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i dont think it would work well.. thats too thick... id use a coler designed for transmissions
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-06-2011, 05:38 PM   #4
maskale
if its easy enough to hook up and u can monitor temps then why not?
take pressure into consideration, I dont know what the trans cooling line runs at, but a heater core is made for rad pressure
maskale is offline   Reply With Quote
Old 12-06-2011, 08:50 PM   #5
ghettoluxury
ghettoluxury's Avatar
I use the factory ac condensor, and it works awesome.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 12-06-2011, 09:10 PM   #6
Hazieview
Wink Re: Unused Heater core for Transmission cooler???
Kind of what I was thinking. I know some people run them on dragsters and circle track cars but I don't know how it would do on a daily driver. I think it would work fine, still unsure though.
SB400 350th
Old 12-06-2011, 11:41 PM   #7
hatzie
Moderator
hatzie's Avatar
The tubes are too big. An ac condenser would work though. I used an ac condenser off a K car as a tranny cooler on my 73 Pontiac station wagon years ago.
Old 12-07-2011, 04:05 AM   #8
INSIDIOUS '86
INSIDIOUS '86's Avatar
its not too little or to much cooling thats the issue its the pressure, ac condenser works under high pressure so it should work, heater core would prob blow all over the road
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-07-2011, 06:23 AM   #9
Hazieview
That is a very good point. After looking at the ac condenser you can also see that the fittings would make it a very easy install too.
As long as the transmission had enough pressure to force the fluid through the ac condenser then it should be fine. However if the volume of the condenser hinders the flow of fluid do to lack of pressure then you are not accomplishing anything. (Honestly I still think it will work fine.)
Maybe I will experiment by installing an inline pressure gauge and temperature gauge.
SB400 350th
Old 12-07-2011, 07:36 AM   #10
gGMC DOG
my only concern would be flow. im sure your trans supply lines flow more volume than a normally functioning a/c...i just dont know how much.
flush the hell out of the a/c condensor core if it's anything other than pristine
gGMC DOG is offline   Reply With Quote
