Building Dreams out of Dimes!
Unused Heater core for Transmission cooler???
Hey guys I have a pretty new heater core laying around that was only used for a short time before being removed. I was thinking of using it as a transmission cooler what do yall think?
I also have a small AC condensor I thought about using... Just a thought. What do you think?
1981 Chevy short/wide. SB400 350th |
Re: Unused Heater core for Transmission cooler???
I would think a mod like that will either cool to much or not enough. Not a good idea IMO.
John 82 Chevy Silverado 350ci/TH350 ![]() |
Robert Olson Transport
![]() Join Date: Oct 2002
i dont think it would work well.. thats too thick... id use a coler designed for transmissions
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
if its easy enough to hook up and u can monitor temps then why not?
take pressure into consideration, I dont know what the trans cooling line runs at, but a heater core is made for rad pressure |
I use the factory ac condensor, and it works awesome.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
#6 | |
![]() Quote:
Moderator
![]() Join Date: Oct 2008
The tubes are too big. An ac condenser would work though. I used an ac condenser off a K car as a tranny cooler on my 73 Pontiac station wagon years ago.
its not too little or to much cooling thats the issue its the pressure, ac condenser works under high pressure so it should work, heater core would prob blow all over the road
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#9 | |
As long as the transmission had enough pressure to force the fluid through the ac condenser then it should be fine. However if the volume of the condenser hinders the flow of fluid do to lack of pressure then you are not accomplishing anything. (Honestly I still think it will work fine.) Maybe I will experiment by installing an inline pressure gauge and temperature gauge. Posted via Mobile Device
my only concern would be flow. im sure your trans supply lines flow more volume than a normally functioning a/c...i just dont know how much.
flush the hell out of the a/c condensor core if it's anything other than pristine |
