Do I need power disc brakes
Planning to add disc brakes up front on a 59 gmc truck with a V-8 SB in it. Do I need to add power or can I get away without power?
Thoughts and opinions are welcome |
Re: Do I need power disc brakes
cant say for sure but im running stock brakes all around and have no issues.
i decided to go with power disc brakes up front on mine. Only because it's an upgraded safety feature. You can easily get away with running stock drum brakes for a s long as you want without any hang ups.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
![]() Join Date: Jul 2012
I went with power in the front for peace of mind.
No, but the first time you have to stop in traffic, you are gonna want them.
Retired and too busy to work. |
Elev8r Man
it makes it alot easier if you add a proportioning valve, if not then most pressure will be applied to the rears instead of the fronts, and when you slam on the brakes the rears will lock up and the back of the truck may pull and try to come around to the front.
ask me how I know ![]() man, I was pulling seat cushion from my behind for a week when that happened
1955.2 C4 Carry-all / Suburban ![]() 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
![]() ![]() Join Date: Nov 2008
I had the same concern over my '55 because I have too radical a cam to develop enough vacuum to operate a booster and after thinking on it awhile, I decided I didn't want to use a hydrovac system.
Any number of guys over on the HAMB told me a manual disc brake system will work just fine and since I already own a CPP disc brake kit, I went looking and bought the frame mount dual master cylinder and bracket. Haven't installed any of it yet because I'll need to run new brakes lines and I don't have the tools to bend it myself....yet!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
#8 | |
![]() I REALLY need to install the CPP kit and dual MC I just mentioned above. I bought both new-but-unused cheaply from Craigslist ads. I'm just procrastinating cause I need a tubing bender (and likely a flaring tool = $$$) and I know once I get it all apart I'll be thinking, "...while I'm doing this..." I should put in Posies Super Sliders, but since I'm doing that, I should order a dropped axle and, while I'm at it have Sid rebuild the kingpins, yada, yada, yada
#9 | |
When I installed my 4wd with disc/drum set up in 1985 (74 K10 donor) I did not use a booster and could lock up the wheels in an emergency. This time I added a booster and PS so my wife can drive the beast.
#11 | |
Elev8r Man
![]() LMAO, And YES, it was an @$$ puckering ride. that was when I decided I needed to go through the truck. I was shaking for about 1 hrs if I remember right. That was about 16 yrs ago. I drove the truck for a couple years and had never pounded on the brakes that hard.
I put manual front disc on my car. Pedal effort is good; same ball park as proper manual drum brakes. Large caliper piston surface area reduces pedal effort. Control is very good. I wouldn't switch to power brakes if free. I don't feel a sacrifice when switching from power brake car to manual brake disc car. Unlike manual vs power steering where the difference is very noticeable.
#13 | |
I do not know if the cost justifies the difference but they are available.
#14 | |
![]() Quote:
Fabguy, Extremely generous of you. I really do want to get to see your shop. As I posted above, my truck is locked up til I get back from vacation about August 9th. THEN, I've gotta go through the whole routine: load the camper on the dually, pull it out, out comes the '55, in goes the boat, back goes the dually, unload the camper again.... ![]() I've been wanting to pull the bed since I took a Sawzall to the old wood so I can thoroughly clean and prime/paint from the cab back. We'll see. Thanks Mike for the heads up on using pre-flared lines. Would save me a lot of headaches and cash cause a GOOD flaring tool is $$$.
#15 |
Dan they are nickel copper and are Dot approved. I am think about using it with stainless flair nuts.
http://www.agscompany.com/automotive...ines/nicopp/11 http://www.jegs.com/p/JEGS-Performan...11534/10002/-1 |
#16 |
Thanks mknittle. Does anyone know if NAPA or other retail parts store carry pre flared nickel-copper lines? Obviously Jegs carries them but I wouldn't want to have to wait for an order to arrive if I mis order and run short.
#17 |
Im not sure if they are nickel or copper plated but i know that they carry the easy to bend lines that are already preflared with fittings on them in several different diameters in metric and standard. They are also in multiple lengths
#18 |
any hand bent line will look hand bent and fly by night
for nice looking, tight to the frame your better of with straight line sections and a bender. you can buy the steel lines at any auto parts store, your 50 yr old oem lines are steel i bought a ss straight line kit from inlinetube.com and supplemented with some short straight sections this way i only needed to flare maybe 5 ends flaring ss tube requires a pro flaring tool, no $40 kit will work once you figure out the bender, replacing all the lines is easy peasy ![]() as far as power vs manual, that is a personal prefference by converting to disc brakes; you will need to update the mc and replace all lines anyway replacing the mc requires converting to hanging pedals or converting the underfloor mc this is probably the hardest part at this point, upgrading to power is easy and usually not much additional cost
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#19 | |
Jeg's sells them in straight sections as the link shows. If I buy the nickel-copper lines it would only be straight, pre-flared & nutted lines and I'd STILL buy a bender to make the bends look clean. I won't much like it if the lines turn greenish. Maybe I could mildly polish them and rattle can clear them(?) Quick question: When to use 1/4" and when to use 3/16"? Is it just one or the other, or 3/16" into the MC and 1/4" out near the wheels? BTW, very sorry for the hijack. Back to the original question: No, I don't think you must have a power booster at all.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 07-31-2013 at 01:00 PM. |
#20 |
Anyone just run power drum?
#21 |
I ran non-power disc on the truck in my avatar pic and it worked very well. No problem with stopping power and good pedal feel. Do your research on pedal ratio if changing to a non-stock brake pedal setup, I used the stock pedal with an adapter bracket from ECI and late model MC and prop valve.
Aout power drum brakes, I had that setup on a 67 camaro and they had lots of power but because they were drum they would go into brake fade if you worked them too hard, easy to do with power drums. I would say don't do it.
1962 Chevy blue SBFS 1957 Chevy yellow SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ |
#22 |
Brake fade is issue with drum brakes. I feel better with the disc setup.
