![]() Join Date: Oct 2010
hidden vin on a 78 swb
Need Help!!! I need to find a 2nd vin # for my 78 GMC SWB. I have the one on the driver door jam, need to find another. The glove box has been replaced at some point so its not there. and of course there is none on the dash, that started in 79. it doesn't have the original motor so its not matching. It should be somewhere on the frame somewhere. I was told by on the driver side by the steering gear box, but not seeing there. Anyone with a 78 could you tell me where I can find it?
2017 Silverado LTZ 6.2 1984 Scottsdale K10 - 468 700r 4x4 lwb 1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb 1968 GMC 20 305 V6 good ole wood hauler. ![]() Good Fences make good neighbors |
Re: hidden vin on a 78 swb
At some point they started stamping it into the top rail of the frame above the cab on the passenger side. I have the cab off of an '84 right now and it's definitely there. You can probably see it with a light and a small mirror.
Mike
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
I have a 77 k3500 it has the vin plate on the door jam and one on the drivers door there is a sticker and it has the vin on a sticker in the glovebox when I took off the bed to paint the frame I could see the vin stamped on top of the right side frame but it was just the last 6 numbers of the vin. and I have not seen the vin anywhere else so I think that is the only places to find the vin.
4x4k30 if trouble was money i would have plenty |
I just went and took a look, and it's actually in two places. One is just above where the fuel tank selector valve goes, and the other is right behind the front bed bolt on the same side.
hey mike does it show the full vin ? I remember when I had my bed off it just had the last 6 stamped in the top side of the frame on the right side behind the first bed bolt hole.
There is some variation between assembly plants (and model years) as to location and whether it was the full VIN or just the sequential portion.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#7 | |
K
I do, where abouts on the trany? I am looking.
Hey guys, thanks! I found it. on my th350 it is on the passenger side of the bell. Thanks again
#10 | |
Mike
#11 | |
Intresting fact that I found, was that gm trucks made in CA(code Z) had the vin stamped on the passenger side of the th350/400's.
#12 | |
They were a long ways away from the watchful eye of Chevrolet Central Office. K
| Bookmarks |
| Tags |
| gmc 78, hidden, vin |
| Thread Tools | |
| Display Modes | |
