Old 07-16-2014, 08:25 AM   #1
parrisc19844x4_468
parrisc19844x4_468's Avatar
hidden vin on a 78 swb
Need Help!!! I need to find a 2nd vin # for my 78 GMC SWB. I have the one on the driver door jam, need to find another. The glove box has been replaced at some point so its not there. and of course there is none on the dash, that started in 79. it doesn't have the original motor so its not matching. It should be somewhere on the frame somewhere. I was told by on the driver side by the steering gear box, but not seeing there. Anyone with a 78 could you tell me where I can find it?
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 07-16-2014, 10:03 AM   #2
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Re: hidden vin on a 78 swb
At some point they started stamping it into the top rail of the frame above the cab on the passenger side. I have the cab off of an '84 right now and it's definitely there. You can probably see it with a light and a small mirror.
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 07-16-2014, 10:09 AM   #3
4x4k30
4x4k30's Avatar
I have a 77 k3500 it has the vin plate on the door jam and one on the drivers door there is a sticker and it has the vin on a sticker in the glovebox when I took off the bed to paint the frame I could see the vin stamped on top of the right side frame but it was just the last 6 numbers of the vin. and I have not seen the vin anywhere else so I think that is the only places to find the vin.
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 07-16-2014, 10:10 AM   #4
Mr.Chevy4x4
I just went and took a look, and it's actually in two places. One is just above where the fuel tank selector valve goes, and the other is right behind the front bed bolt on the same side.
Old 07-16-2014, 10:23 AM   #5
4x4k30
4x4k30's Avatar
hey mike does it show the full vin ? I remember when I had my bed off it just had the last 6 stamped in the top side of the frame on the right side behind the first bed bolt hole.
Old 07-16-2014, 11:07 AM   #6
Keith Seymore
Keith Seymore's Avatar
There is some variation between assembly plants (and model years) as to location and whether it was the full VIN or just the sequential portion.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 07-16-2014, 11:08 AM   #7
Keith Seymore
Still have the original transmission? It should be on the trans as well.
K
1979-1986
1986 - 2019
Old 07-16-2014, 11:57 AM   #8
parrisc19844x4_468
K
I do, where abouts on the trany? I am looking.
Old 07-16-2014, 12:50 PM   #9
parrisc19844x4_468
Hey guys, thanks! I found it. on my th350 it is on the passenger side of the bell. Thanks again
Old 07-16-2014, 04:24 PM   #10
Mr.Chevy4x4
On my 84 K30 frame it is the 3rd-5th characters CGF (after the "1G") and the last 6 numbers (sequence).
Mike
Old 07-17-2014, 10:31 AM   #11
parrisc19844x4_468
Mike
Right , my 84 is the same. I had that to check but the vin # for the 78 are not the same and not located in the same locations. I believe onward from 81they had to be 17 characters.
Intresting fact that I found, was that gm trucks made in CA(code Z) had the vin stamped on the passenger side of the th350/400's.
Old 07-17-2014, 11:22 AM   #12
Keith Seymore
Fremont had a lot of little things they did differently.
They were a long ways away from the watchful eye of Chevrolet Central Office.
K
1979-1986
1986 - 2019
gmc 78, hidden, vin
