Old 12-26-2015, 12:06 PM   #1
mjensen
mjensen's Avatar
Opinions or ideas needed
I've got my new to me 205 installed, and now I need to figure out just what to do with the drive shaft. The way it sits right now, it's going to hit the cross member that housed the old carrier bearing. The way it sits, it's about a 12 degree slope from the tailshaft to the pinion on the rear end. I figure I have two options, 1 would be to lower the cross-member holding up the tcase, or 2 just modify the cross member to provide some clearance. Any ideas of what I should do would be greatly appreciated.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 12-26-2015, 03:10 PM   #2
Brad54
Brad54's Avatar
Re: Opinions or ideas needed
Clearancing the crossmember is going to be a whole lot easier than lowering the t-case.
You should easily be able to clearance and reinforce the modified area on the cross member.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 12-26-2015, 03:24 PM   #3
mjensen
mjensen's Avatar
That was my thought too. Thank you Brad!
Mike
Old 12-26-2015, 03:52 PM   #4
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Some type of driveshaft loop might work.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 12-26-2015, 04:23 PM   #5
kwmech
I skimmed through your build thread and was trying to find where you mounted your engine. Would be a good time to move it forward before the drivelines are built. I know the t-case is already done, but if you convert the rear of the case to a fixed yoke it will all clear without frame mods.
Old 12-26-2015, 05:25 PM   #6
obijuan
Fixed yoke will fix all your problems
obijuan is offline   Reply With Quote
Old 12-26-2015, 08:08 PM   #7
BigRed76
BigRed76's Avatar
I agree with going to a fixed yoke on the rear of the t-case. It will shorten up the overall length of the t-case, plus it's what these trucks came with anyways.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 12-26-2015, 08:59 PM   #8
mjensen
mjensen's Avatar
I was thinking about looking for something like that today.
Well, I moved my motor forward 2 inches already. With the torque splitter installed though, it pushes everything back 5-1/2". I was looking at the fixed yokes today, but couldn't justify buying the kits to do it.
If I can find a fixed yoke at a decent price, then I will probably go that route. If not, I'll just modify the xmember.
Thanks all!!!
Mike
Old 12-26-2015, 09:07 PM   #9
franken
How will a fixed yoke change the centerline or angle? The DS will hit that crossmember regardless unless there's a huge lift.
The carrier bearing center would be what 3-5 inches below what it is in the pic if it was still there? My guess is something has been changed and the rear of the TC needs to come way down.
Old 12-26-2015, 09:25 PM   #10
obijuan
All you need is a rear output shaft, seal retainer, and seal. 100 bucks on ebay.
Old 12-26-2015, 09:26 PM   #11
mjensen
mjensen's Avatar
The fixed yoke does not stick out from the housing nearly as far. This would add quite a bit of clearance without modifying the crossmember. Oh, and yes a lot has changed on this truck LOL. I've added a torque splitter, which adds 7-1/2" between the bell housing and transmission. This truck also came with a T221 TCase. I'm planning on running a one-piece driveshaft.
Mike
Old 12-26-2015, 09:28 PM   #12
mjensen
mjensen's Avatar
I think I'll start looking. If I'm going to do it, I only want to build the driveshaft once LOL
Mike
Old 12-26-2015, 09:35 PM   #13
obijuan
And a nut with a flange or a washer
Old 12-26-2015, 10:51 PM   #14
franken
Take a pic of the cenerline of the TC and diff.
Old 12-27-2015, 02:08 AM   #15
kwmech
Since you moved the engine forward already, even with the fixed yoke you will have notch the member....just not nearly as much. Your drive shaft will probably need to be at least a 2.75'' tube minimum, being a 1 piece
Old 12-27-2015, 01:16 PM   #16
mjensen
mjensen's Avatar
I'll try to snap a pic when I get in the garage today.
That's what I was thinking. I'm going to take it down to the local driveline shop to have them evaluate everything, but they want the body and everything on it so they can measure it correctly.
Mike
