11-13-2024, 08:59 AM | #176 |
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
I love the consistent progress! What's next on the list to tackle?
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
11-13-2024, 10:42 AM | #177 | |
I was under the impression that the gears in my truck were the original gears since 3.73 was standard equipment, and the SPID doesn't list the ratio. I was reading the optional equipment list in the sales brochure for 1971, and it says a 350 engine gets 3.07 gears. My SPID lists a 350 engine. It is obvious that someone has worked on both the front and rear gears on this truck, so it was probably to swap the original 3.07 gears for 3.73 gears. |
11-13-2024, 05:28 PM | #178 | |
11-13-2024, 05:45 PM | #179 |
Hmm. My SPID lists a 350 engine and a 4-speed transmission. Here's the table from the 1971 sales brochure that had me wondering about the gears. The brochure also says that 3.07 will be included with a 350 engine.
11-13-2024, 06:49 PM | #180 |
OK. IDK.
My '71 GMC Jimmy K/1500 was originally equipped with V8 350/SM465/NP205/ 3.73 w/Posi. I have a 1972 Chevy K/5 Blazer Tub/Chassis out the 'Back Forty'. While it has no Engine, Transmission, or Transfer Case, and no Glove Box Door [ergo, no SPID], the Rear Differential was a 3.07 when I opened it up and counted teeth. This Blazer was originally an Auto Tranny truck. Flint build.
11-13-2024, 06:51 PM | #181 | |
11-13-2024, 07:07 PM | #182 | |
Since White Fang and 919 both were 3.73 trucks, I made the assumption 3.73 was always STD.
11-13-2024, 07:24 PM | #183 | |
The funky shims in my rear diff, and new bearings in the front diff point to a gear swap. |
11-14-2024, 02:15 AM | #184 |
I wish my SPID were as clean as yours. Mine has been exposed to the weather for who knows how long because the windshield was missing.
11-14-2024, 06:02 PM | #185 | |
As an inner-city security feature, the Door Lock Knobs and relay rods had been deleted. The doors were kept locked and when picking up the spouse, she/he had to user their key to open the door, they told me. About 4 or 5 years later I made a road trip up to the Bay Area, and Jerry Moss gave me a pair of Relay Rods, when I bought a Blazer Windshield Frame from him.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 11-14-2024 at 06:15 PM. |
11-15-2024, 01:33 AM | #186 |
I finished a batch of dummy filler necks two days ago and had some two part epoxy paint and primer left over that needed to be used up. This evening I cleaned up the front brake caliper brackets/dust shields, some little parking brake parts and some original stepside rear bumper gravel shields and painted them.
11-15-2024, 07:46 AM | #187 |
It's hard to find those dust shields still intact. Yours look solid, there usually rusted away or damaged.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
11-15-2024, 11:04 AM | #188 |
I straightened out a couple of bent corners on them, and one appears to have detached partially from the caliper bracket at some point and got welded back on. The metal is still thick and solid though. I noticed that the single mounting screw for each dust shield is missing.
11-15-2024, 12:27 PM | #189 |
If the threaded hole in the knuckles isn't there, then I would suspect either the knuckles or front axle have been changed at some point. You could look up the axle numbers.
My dust shields were in about the same shape. Gary
11-15-2024, 01:25 PM | #190 |
The threaded holes are there, and thankfully there aren't snapped off bolts in them, which is what I was half expecting to find.
11-15-2024, 01:43 PM | #191 |
The truck should be down off of jack stands soon.
11-15-2024, 04:46 PM | #192 |
Nice, so that's most likely the original front end. After 72 those holes were no longer.
11-16-2024, 12:21 AM | #193 |
This evening I installed the rear brakes. Lubed up the parking brake cables and installed new rubber boots on them. Installed the shoes and hardware. I was missing one parking brake strut spring, so I had to run to the auto parts store to buy some. Installed 67-70 style drums because i had an extra set already. The rear wheels are back on and sitting on the ground.
11-16-2024, 08:32 AM | #194 | |
This part number is used from 1971-74 in the later parts catalogs.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
11-16-2024, 11:00 AM | #195 |
11-16-2024, 11:05 AM | #196 |
Except the boss in the casting is no longer there.
11-16-2024, 11:08 AM | #197 |
Isn't this the boss?
11-16-2024, 11:11 AM | #198 |
11-16-2024, 11:30 AM | #199 |
Oh yeah, I was thinking it was on the other side.
It does look like the studs are clocked a little different.
11-16-2024, 12:00 PM | #200 |
The Ebay knuckle might be a 1969 or 1970 knuckle. That is the problem with converting the open knuckle 1969 and 1970 Blazers/Suburbans/trucks to disc brakes. The studs are clocked wrong to mount the caliper bracket.
Here is a purported 1969-70 NOS knuckle 360048 My 1972 donor knuckles had the single 1/4"-20 threaded hole to support the splash shield.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels Last edited by 1970cstblazer; 11-16-2024 at 12:07 PM. |
