Old 01-01-2025, 02:05 PM   #1
a Good Man
a Good Man's Avatar
Need help for v belts part numbers
happy new year to all
need help for v belts part numbers for my gmc k2500 1972 ( napa or good year )
vin number is : Tke242z513060
big thanks
MY Facebook
( saad_alhajri ) on Instagram
a Good Man is offline   Reply With Quote
Old 01-01-2025, 02:07 PM   #2
kwmech
Re: Need help for v belts part numbers
Any numbers on the existing belts?
Old 01-01-2025, 02:14 PM   #3
a Good Man
a Good Man's Avatar
I got lost on the way ‏Alternator belt But the other belts I have a number .
MY Facebook
Old 01-01-2025, 03:46 PM   #4
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Need help for v belts part numbers
GM belt part numbers. Usually located on Ebay.
Old 01-01-2025, 04:44 PM   #5
a Good Man
a Good Man's Avatar
I just want to know the part number napa or good year Alternator belt .
MY Facebook
Old 01-01-2025, 05:12 PM   #6
Rust_never_sleeps
Rust_never_sleeps's Avatar
I have these in my notes. Chevy, but my layout is the same as yours:
Belts:
PS GATES 7350
alternator GATES 7525
AC+fan (for AT vehicles w/o airpump) GATES 7555
Hope this helps
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 01-01-2025, 05:20 PM   #7
a Good Man
a Good Man's Avatar
Hope this helps
This item doesn't fit ( alternator GATES 7525 )
MY Facebook
Old 01-01-2025, 06:23 PM   #8
kwmech
Belt numbers indicate the belt length. So the PS belt shown is 15356 15/32 wide and 35.6 inches long. The 25-7555 is 10mm wide and 55.5'' long ( I don't know what the 7 means) and the alternator belt is usually 52.5 long, but I recently installed an alt upgrade to a 1 wire on a truck and the belt length needed was a little longer and I still had to force it on a little at 53'' long so it took a 15530. Hope that helps. The gates shown before this post shows a 7525 --7/16'' wide and 52.5 long
Old 01-01-2025, 06:56 PM   #9
Rust_never_sleeps
Maybe you have the 62A alternator, or... :shrug:
Old 01-01-2025, 08:18 PM   #10
1970cstblazer
Thumbs down Re: Need help for v belts part numbers
A smart man would know to cross reference to get the right belt....
Old 01-02-2025, 12:05 AM   #11
Sheepdip
Sheepdip's Avatar
If worse comes to worse, wrap a rope around it and measure to get a starting point for a belt length.
Sheepdip is offline   Reply With Quote
Old 01-02-2025, 01:04 AM   #12
a Good Man
a Good Man's Avatar
A smart man should know that in my country these belts are not available so he should order them in the correct size from the Internet
MY Facebook
Old 01-02-2025, 05:30 AM   #13
a Good Man
a Good Man's Avatar
this Alternator who needs a belt .
MY Facebook
Old 01-02-2025, 05:33 AM   #14
a Good Man
a Good Man's Avatar
No sir its 63A
MY Facebook
Old 01-02-2025, 06:51 AM   #15
Rust_never_sleeps
No sir its 63A
I mentioned that because rockauto listed a different belt. Worth a look since they show different options for several combinations of accessories. If you click the info button, it will show belt dimensions
Also agree with the suggestion to measure the path with a rope or tape measure. Belt length is measured at the outside edge of the pulleys.
Old 01-02-2025, 07:13 AM   #16
a Good Man
a Good Man's Avatar
I appreciate it sir , Thanks
MY Facebook
Old 01-02-2025, 02:06 PM   #17
Classic Bowties
Always on the hunt...
Saad, as an FYI that alternator shown in reply #13 is not the correct model/type for your 72 K2500, if interested in more info and pics on the 71 and prior vs. 72 style alternator subject see the below linked thread post #10, #16 and #20. Happy New Year and good luck in your search, Mel in Oregon
http://67-72chevytrucks.com/vboard/s...d.php?t=855980
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 01-02-2025, 02:19 PM   #18
a Good Man
a Good Man's Avatar
Very clear. Thank you sir and happy new year
MY Facebook
Old 01-02-2025, 05:44 PM   #19
Accelo
Accelo's Avatar
As information only the X in the number is for the clogs on the inside of the belt.
it makes no difference on the sizing. They are rated for smaller diameter pulleys and higher HP than the belts with the smooth inner. Either with or with out the X in the umber will function fine. I believe this "X" type of belt was invented after out trucks were made. OEM belts of this era were all smooth on the inside.
Cheers
Accelo is offline   Reply With Quote
Old 01-04-2025, 07:16 PM   #20
MikeB
MikeB's Avatar
Try this:
https://www.rockauto.com/en/catalog/...rive,belt,8900
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-05-2025, 01:46 PM   #21
a Good Man
a Good Man's Avatar
Cheers
MY Facebook
Old 01-05-2025, 01:46 PM   #22
a Good Man
a Good Man's Avatar
Originally Posted by MikeB View Post
Purchased Thank you
MY Facebook
