Old 04-15-2025, 07:20 PM   #5301
zicc1835
zicc1835's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by un4gvn! View Post
I got the 540 installed and running.
I like everything about it ....let's hear it running
zicc1835 is offline   Reply With Quote
Old 04-21-2025, 10:59 PM   #5302
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Installed a set of NOS door latches, and new metalized tape on the frame around the wood grain. I had originally installed the tape with the panels off, but noticed I missed part of the top ledge on one side, so fixed it with the panel on, which was actually easier. I used 1/2" wide for the top and bottom frame, and 3/8" for the sides. Sides are easier to center, so 3/8" is perfect - just happened to have both sizes.
With new latches and warm weather, the doors finally close nicely with new weatherstrip.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-25-2025, 05:38 PM   #5303
72c20customcamper
72c20customcamper's Avatar
Took the 68 Stepside to my mom’s house drove mostly two lane highways around 55-60 mph . The round trip was 125 miles and I used 6.6 gallons of gas . 18.939 miles per gallon I’m just calling it 19 , not bad for a 250 with a sm465 I was under the impression it was a 4.57 rear but I changed out the gear oil and it’s a 4.11 . But still pretty impressive milage from a brick
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-25-2025, 08:32 PM   #5304
weq92f
weq92f's Avatar
I made it sit all alone inside the ropes at the Good Guys Spring Nationals Rod and Custom show today at TMS while I made my way through a small percentage of the PATE swap meet just outside the speedway in the parking lot.
Tomorrow I'll be there again with my truck and will enjoy the car show festivities with friends.
Come by and say hello if you find yourself at the show.
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 04-29-2025, 07:53 PM   #5305
69Penka
Finished putting my truck back together after the paint job. Added a slider, cargo light and three point seat belts. Can't decide if to add the headache rack or not. Thoughts?
69Penka is offline   Reply With Quote
Old 04-29-2025, 07:56 PM   #5306
69Penka
Couple more with the rack on.
Old 04-29-2025, 07:57 PM   #5307
zicc1835
zicc1835's Avatar
lookin real good
Old 04-30-2025, 06:19 AM   #5308
Jiggers72-GMC
Wow, she looks great, I like it without the rack but you do what you want to ..........
Jiggers72-GMC is offline   Reply With Quote
Old 04-30-2025, 11:55 AM   #5309
69Penka
Originally Posted by zicc1835 View Post
lookin real good
Thank you zicc!
Old 04-30-2025, 11:56 AM   #5310
69Penka
Thank you Jiggers!
Old 05-01-2025, 08:03 AM   #5311
'68OrangeSunshine
'68OrangeSunshine's Avatar
Racks are good and if you're in jeopardy of a steel pipe or long 2 x 4 board sliding forward and breaking your rear window, then use the rack. If you're not using the truck to make a living doing these crafts, then a Headache Rack is pretentious, excess weight, and aerodynamic drag.
But it's your truck.
Old 05-01-2025, 04:48 PM   #5312
72c20customcamper
Love the look hate the maintenance. Spent 2 hours with Mothers polish by hand just can’t bring myself to use a power ball my luck I’d ruin a rim . Was planning on going to a show Saturday and Sunday but the weather changed from partly cloudy to rain. And now it’s suppose to rain all week
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-03-2025, 02:51 AM   #5313
Edmond
Edmond's Avatar
Beautiful truck
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
The Netherlands
Edmond is offline   Reply With Quote
Old 05-03-2025, 09:00 PM   #5314
1970Tex
1970Tex's Avatar
I think i finally solved my leaking TH350. Swapped out the shift shaft as the original one had significant wear on it. There is a definite ridge around the seal area not quite visible in the picture. The rebuild shop didn't catch it, but they were nice enough to give me a used one. Weirdly they both have a gouge in the same spot, but otherwise shes good.
1970 GMC C/K1500 SBC 350/TH350 3/4" drop. Original tuxedo black paint. 20" American torque thrust. Front disc brake/ 5 lug conversion.
1970Tex is offline   Reply With Quote
Old 05-03-2025, 10:28 PM   #5315
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
I should try this. I put in a new seal years ago and it still leaks. It's the original shaft. I went to a local trans shop to see about getting it fixed, and they want $167.50 minimum for any work. Fortunately, he had a Mercedes something or other that was occupying the heavy hoist. I can buy a new shaft and seal for a bit less than that. I guess I'll have to do it myself. #CHEAPSOB Except I have a bit of trouble getting up and down, what with uncle Arthur visiting all my joints.
BoT, I drove my truck to a local car show but it started raining and the show fizzled. Member @Richard and I had a burger and chatted for awhile out of the weather.
~Steven
Simi Valley, CA
Old 05-04-2025, 09:55 AM   #5316
raggedjim
raggedjim's Avatar
You might try one of these seals. It seals at 2 different places. I've never tried one but kept the post for future reference.
https://67-72chevytrucks.com/vboard/...27&postcount=1
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 05-04-2025, 08:01 PM   #5317
Steeveedee
Steeveedee's Avatar
Good luck, Rg
It did occur to me that the seal wore one section of the shaft, but I never thought about a seal like this. Thanks for mentioning it! I'll check it out.
ETA: Looked at that thread. The seals are certainly cheap enough, but I don't need 5. Still worth the money. I'll see if they work on a 400 THM.
~Steven
Simi Valley, CA
Old 05-04-2025, 09:20 PM   #5318
PbFut
I attempted this repair 3 or 4 times. The shaft appeared in perfect shape and would leak a little or even a lot after each attempt. I think I was nicking the seal on the machined lip. Replaced shaft and seal in a somewhat reverse manner and it's been leak free almost 2 years. Now that I post about it, there will be a pubble on the floor in the morning. Just like I bragged about my 53 year old driver window regulator working so well last week. Guess what's in the mail for replacement this week.
PbFut is offline   Reply With Quote
Old 05-05-2025, 09:06 AM   #5319
Lee H
Lee H's Avatar
Scrubbed it off and went to a car show. Left the driver's door window down and someone threw a flyer about a future car show in. #litter
Member #Richard and I had a good time chatting and looking at the old iron. Had burgers at the Rock and Roll Cafe, too. I saw several examples of vehicles I had and never should have sold.
I should try to catch up with you guys at a car show sometime. It's been a long time since I've been to car shows.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-05-2025, 11:07 AM   #5320
Steeveedee
Steeveedee's Avatar
First Saturday of the month, starts at 4 PM. Everyone is welcome! No show in July this year, there's a big one in Moorpark.
~Steven
Simi Valley, CA
Old 05-06-2025, 01:40 PM   #5321
72c20customcamper
Installed the new heater control on my 68 stepper and I bought 2 sets of Trico Classic wipers. They were $10 each guy gave me the 4 for $35 at the Rhinebeck or as we call it the Rainbeck show as it rains every year ,
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-06-2025, 08:19 PM   #5322
'68OrangeSunshine
I bet they hold their shape better than the black plastic ones.
Here in AZ the sun kills the rubber before they're a year old, anyway.
Old 05-06-2025, 11:33 PM   #5323
allchevy58
allchevy58's Avatar
Finally installed chrome tailgate handle cover. Met Eric (Chevyland) at C10 Intervention Woodland 2024 and he informed me that my truck should have it being it's Sierra Grande. He sent it within a week of the show and I just got around to installing it. Thank You Eric
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 05-07-2025, 11:03 AM   #5324
72c20customcamper
They make the complete blade but no refills . Even though the blade can come off just like the originals makes no sense
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-07-2025, 09:39 PM   #5325
3757chevy
3757chevy's Avatar
The refills are available through Classic Industries.
https://www.classicindustries.com/pr...E&gclsrc=aw.ds allthough they are rather expensive after you pay shipping
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
