Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-23-2011, 10:07 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Those with trailing arm rear suspension
I will be swapping the rear suspension out in my 85 to the trailing arm style like in the older trucks. I want it to hook at the track and still have a good ride on the street. I am thinking of going with coil-overs in the rear, can those of you that have done this to ur trailing arm suspension post up some pics and details on what you used? Thanks.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 01-23-2011, 11:03 PM   #2
ripdog28
ripdog28's Avatar
Re: Those with trailing arm rear suspension
Check out my build for pics, Ill be going to coil overs soon. I have Boxed trailing arms. Only reason i'm staying with them is they are original. IMO, why go this route when a 4link would cost less and most likely work better for you? You will be doing just as much cutting/grinding/fab work with either one but the 4 link has more adjust ability.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 01-24-2011, 03:07 AM   #3
Super73
Super73's Avatar
Right, and most people can't figure out the endless adjustments to make things work properly. It is much easier to get a ladder bar style suspension like the trailing arms to work if you don't know what you are doing.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-24-2011, 03:14 PM   #4
softballnrd27
What he said. I want to copy a working suspension and it seems that more people on this site have the trailing arm suspension so if something isn't right I can pretty much get the answer here.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 01-24-2011, 03:25 PM   #5
softballnrd27
Ripdog- looked at your link and what is the watts link for? Is it stronger/better than the trac bar?
Anyone with some pics of a coil-over install and what you used?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 01-24-2011, 07:44 PM   #6
ripdog28
ripdog28's Avatar
The watts link (Watts being the inventor) is much better at keeping the axle centered then the Trac bar. In my set up it will allow for over 12in of susp travel and maintain the axle in the same spot vertically. The trac bar does have side to side movement. Lots of on it. Im not saying you should not do a trailing arm set up, just that it is as much work as others with more options. Also, the Watts Link and trailing arm set up is what NASCAR uses. If your not into the Watts, Hotrods to hell offers a truck arm set up.
69 c-10 BBC
Old 01-24-2011, 08:42 PM   #7
softballnrd27
I will probablt use the CPP kit minus the arms. I know what you're saying about the trailing arms vs 4 link from a fabrication standpoint, but like super73 said, the amount of adjustments and what can go wrong with the 4 link(as far as dialing it in) makes it notworth it to me right now. Once I think I know something about suspension geometry then I might dive into something like a 4 link.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 01-24-2011, 09:02 PM   #8
ripdog28
ripdog28's Avatar
Super also recommended a ladder bar set up. Very similar to trailing arms and far less adjustment then a 4 link. Again, same fab work involved. If your doing trailing arms, you need to be very careful to get the arms set at the same angle outwards, same distance mounted from center of axle, and a few other things. Anything you do to the axle other then mount leaf springs will involve lots of measuring. Take your time and measure lots.
69 c-10 BBC
Old 01-24-2011, 11:37 PM   #9
Wild83C10
Wild83C10's Avatar
Here are some pictures of my conversion. Most are prior to completion. CPP crossmember, stock (welded seam) arms, QA1 coilovers, Chassis Engineering coilover mounts.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 04-18-2011, 10:48 AM   #10
xteamxtreme
xteamxtreme's Avatar
Thats a badass setup. Did you weld the full length of the seem on both sides of those trailing arms?
xteamxtreme is offline   Reply With Quote
Old 04-18-2011, 07:06 PM   #11
softballnrd27
Wild83-What is the dollar amount you have in the rear suspension? You can PM in need be. Did you only use the CPP xmember? I was thinking of getting the whole kit minus the arms.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 04-19-2011, 06:20 AM   #12
Wild83C10
Wild83C10's Avatar
I didn't weld the whole seam, just 2" every 8-10".
softballnrd27, first thanks for your service. Not sure on the exact cost but here is what I believe everything cost:
trailing arms, used: $100
crossmember from CPP: $175-$200?
Coilover shocks: QA1 $150ea
Springs: QA1 $60
coilover mounts: chassis eng. $50
Perches: CPP $?
Adjustable Track bar: CPP $170
turbo=
Old 04-19-2011, 07:04 AM   #13
softballnrd27
Hey thank you for your support!!
Thanks for the prices, I saw in your swap thread all the part numbers after I posted that, I should have deleted the post.
I need more info on that turbo setup!! It looks sweet!!!
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 04-19-2011, 07:14 AM   #14
bigsnookmaster
bigsnookmaster's Avatar
I used QA1 coilovers mounted in front of the rear, Porterbuilt trailing arms and crossmember,and built my own panhard bar and bracket. I am thinking about changing the panhard bar to a wishbone type setup. Here's a few pics:
bigsnookmaster is offline   Reply With Quote
Old 04-19-2011, 03:30 PM   #15
xteamxtreme
[QUOTE=Wild83C10;4633192]I didn't weld the whole seam, just 2" every 8-10".
so being that i have a c20 3/4 ton, and the trailing arms have an extra plate for strength. How would you recommend welding to be done?
Old 04-19-2011, 03:31 PM   #16
xteamxtreme
What does it cost for that porterbuild set up? and can you provide me with the website? thanks.
Old 04-19-2011, 06:43 PM   #17
bigsnookmaster
I'm not sure what it costs new, I bought it off another member on the board. It's real nice stuff, and Nathan from Porterbuilt is also a member and vendor of this forum. Go to Porterbuilt streetrods.com. Nathan is also a great guy!
Old 04-19-2011, 09:39 PM   #18
Wild83C10
Wild83C10's Avatar
Hey no problem.
Let me know what you want to know about the turbo setup and I will provide the info.
turbo=
Old 04-19-2011, 09:42 PM   #19
Wild83C10
Wild83C10's Avatar
Is the plate on the top and bottom of the arm? If so then I wouldn't worry about doing anything else other then verifying it's not rusting out in the middle. I think the CPP trailing arm reinforcing kit is a top and bottom plate.
turbo=
Old 01-28-2012, 09:47 AM   #20
taank
Where did you get the lower mounts? Is it welded to axle or just sandwiched ?
taank is offline   Reply With Quote
Old 01-28-2012, 11:33 PM   #21
Wild83C10
Wild83C10's Avatar
What lower mounts? The trailing arm to axle perches? They are fully welded now, not like in the pictures.
turbo=
Old 01-29-2012, 09:13 AM   #22
taank
The coil over lower mounts.
Old 01-29-2012, 09:58 PM   #23
Wild83C10
Wild83C10's Avatar
The lower coilover mount is a competition engineering mount (I think) and it's welded to the housing.
turbo=
Old 01-30-2012, 03:40 AM   #24
TheCustomFactory
TheCustomFactory's Avatar
Or you can build adjustable trailing arms like i did. I can transfer the weight forward or backwards.
TheCustomFactory is offline   Reply With Quote
Thread Tools
Display Modes
