Old 12-03-2004, 07:01 PM   #1
Deuce
Deuce's Avatar
TPI Conversion Guys Out There......Question.
Can anybody tell me what I need to keep out of a factory 87 IROC harness to make the engine in my 68 work??
I'm in the process of pulling the motor/trans out of the car and there are a ton"o"wires!! What can I eliminate??
Thanks in advance!!
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 12-03-2004, 07:22 PM   #2
71swb4x4
71swb4x4's Avatar
I would recommend not eliminating anything until you get the whole thing out.
After that you can eliminate the wipers, and air conditioning. You can eliminate the following if you aren't using them: electric fans, EGR, charcoal canister, and AIR pump.
I am sure I am forgetting a few things too.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-03-2004, 08:29 PM   #3
CHEVYE
my gas saver
CHEVYE's Avatar
yeah make sure and pull it all, dist, wires, complete harness, ecm under pass side dash, air intake duct prior to engine. make sure and get all sensors too and i would even snag the press regulator and fuel pump. it stinks missing anything and hunting it down.
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 12-03-2004, 11:28 PM   #4
neonlarry
neonlarry's Avatar
its not hard to get all of the wireing out (I would know, I have pulled 2, and taken a 3rd one partway apart) just start at the computer, and follow it around to the bulkhead connector on the other side.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 12-04-2004, 01:44 AM   #5
Deuce
Deuce's Avatar
So I don't need the EGR or Charcoal canister???
Old 12-04-2004, 01:50 AM   #6
Deuce
Deuce's Avatar
Can a mod move this to the messege board please.
Sorry for posting in the wrong section...............I was in a hurry to leave work!!!
Old 12-04-2004, 02:10 AM   #7
gonebad2
Merciless Butcher
gonebad2's Avatar
I parted a 99 Camaro( LS-1 Automatic) and was totally amazed at the amount of wiring that was in that car. I cut no wires and carefully removed everything from the taillights to the headlights. I even left everything just as it was connected at the factory. If a sheetmetal panel was in the way, I cut it or split it just to keep the entire harness intact. This was complete overkill and a major pain. Most of the wiring was not needed for a conversion and was later tossed. The pile of wiring was actually taller than the engine when it was piled next to it.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 12-05-2004, 02:50 PM   #8
Deuce
Deuce's Avatar
Anybody try using the electric fans and rad from the camaro also??
Old 12-06-2004, 02:14 PM   #9
71swb4x4
71swb4x4's Avatar
Deuce
I am not using the charcoal canister or EGR on mine. I did have the chip reburned to compensate for the EGR removal.
Old 12-06-2004, 03:47 PM   #10
Deuce
Deuce's Avatar
Deuce
Are you using a speed density system or mass air?? I'm using the mass air(87 IROC)
Can tou tell me what I need to keep??
Thanks.
Old 12-06-2004, 06:37 PM   #11
71swb4x4
71swb4x4's Avatar
I am using Mass Air.
I elminated everything I listed in my first post. I had a 305 TPI so I ditched the 19lb injectors and got larger ones.
