Old 12-09-2004, 07:40 PM   #1
ocbaud
Garage Queen Material
my truck smokes :(
in the second video, you can see it smoke whenever i rev it up i checked all the plugs and they all looked great. from what i see, it only does it when its in park and idling and i rev it like that. it doesnt smoke while i'm driving either.
www.ocbaud.com/videos/idlenew.AVI
www.ocbaud.com/videos/revlow.AVI
ocbaud is offline   Reply With Quote
Old 12-09-2004, 08:37 PM   #2
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Thats called blowby!! when oil blows by the rings!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 12-09-2004, 10:54 PM   #3
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
ocbaud I've got a killer short block I'll sell you
Grande Rojo is offline   Reply With Quote
Old 12-09-2004, 11:10 PM   #4
Goodys86
Goodys86's Avatar
Do you have to add oil very often? From what I could tell it doesn't look that bad. Also, I have a video of my truck if anyone wants to host it.
86 C-10 SWB 2wd
-355/TH350, 3:73's (Vin# says its a V6)
Best ET: 13.0 @ 101mph (NA)
11.9 @ 108mph (100 shot)
02 Chevy 2500HD DMax (tow vehicle)
84 GMC Sierra 2500
00 Formula M6 hardtop
Goodys86 is offline   Reply With Quote
Old 12-09-2004, 11:16 PM   #5
cochran63
cochran63's Avatar
My new 327 was doing something similar, it turned out to be the adjustment of my holley that was causing the proble's. I got it tuned up and havent had any more problems.
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 12-10-2004, 12:15 AM   #6
78chevstepside
78chevstepside's Avatar
Msybe it needs the patch
78chevstepside is offline   Reply With Quote
Old 12-10-2004, 12:35 AM   #7
1FaastC10
1FaastC10's Avatar
my 355 did this when i built it in '98. i didnt have the time, or the money to tear it down and fix it. so i let it go. 7000-8000 miles later, it stopped. someone told me that it was the rings seating against the cylinder bores.
1FaastC10 is offline   Reply With Quote
Old 12-10-2004, 12:46 AM   #8
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I would try a very complete compression test of the engine. This will tell you a little more about what its doing. I might be over looking it but it doesn't look like much smoke at all to me.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 12-10-2004, 12:56 AM   #9
low 84
low 84's Avatar
a compression test won't really tell you anything unless there is a large difference in numbers cylinder to cylinder. you need to do a leakdown test if you want to check the rings.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 12-10-2004, 01:09 AM   #10
MylilBowTie
Right turn Clyde
Yes I forgot to add the more important of the two tests.
Old 12-10-2004, 01:59 AM   #11
ocbaud
like i said, it only does it while i'm idling and not moving, i've had friends following me and they tell me that they dont see any smoke come out when i get on the gas hard.
whenever it is idling there is small amounts of fuel coming out of the exhaust, the carb is running way rich and will be until christmas when i get my pressure regulator.
Old 12-10-2004, 02:07 AM   #12
James670X
I'm assuming your truck is carbureted?. From the looks of it I'd say it's running a little rich.
James670X is offline   Reply With Quote
Old 12-10-2004, 02:11 AM   #13
ocbaud
a lot rich, but only at idle.
the edelbrock carb doesnt like more than 5.5psi MAX at idle and my fuel pump puts out between 6-9 psi at idle.
Old 12-10-2004, 03:07 AM   #14
James670X
Blowby would make the tips of your spark plugs oily.
Have you considered buying a pyrometer or egt gauge?
Old 12-10-2004, 03:23 AM   #15
ocbaud
all of my plugs looked just like this:
Old 12-10-2004, 04:45 AM   #16
C-10volvo
C-10volvo's Avatar
thoes plugs look like the motor is rich. from what i can tell from the vid, the smoke is black, not blue. i think you should be fine when you get that fuel pressure regulator. or re jet your carb
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 12-10-2004, 04:55 AM   #17
ocbaud
i cant ever see the smoke since i'm in the cab with my foot on the gas. the truck smells very rich though. and i wouldnt be able to tell if it was blue or white or what not since i'm color blind
Old 12-10-2004, 09:31 AM   #18
low 84
low 84's Avatar
it most likely does it while your moving too, the smoke just dissipates into the air quickly when the truck is moving. when its stationary like that it just makes it easier to see. it doesn't really look like enough to worry about to me. get your carb dialed in and it might take care of it
'05 1500 Crew Cab
RIP
Old 12-10-2004, 01:48 PM   #19
ocbaud
i have some people on another forum telling me that my plugs look like they are running VERY lean??
Old 12-10-2004, 07:42 PM   #20
phantom dually
Lean would be alot more white on the plug.
