Professional Grade
Interesting turn-signal issue
Hey guys!
What would cause one signal light to work normally, 4 way flashers to work normally, but the other signal light to stay on steadily? This isn't on my truck, but I figured that they should be the same...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
If it stays on repeatedly when the lever is depressed, that would be a bad bulb or messed up wiring on that side.
Flashers have a "seperate" circuit in most vehicles so you can't really use them to test anything but theirself. |
I would have to say a bad bulb on the side that stays on.
Stepsides RULE
yeah bulb, probably brake light or taillight of that side. i had the same problem back in june or july.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
