Old 12-11-2004, 02:09 PM   #1
bodazpa
bodazpa's Avatar
4 wheel steer 1972 blazer?
Does anybody rember the red 1972 blazer that had 44`s and 4 wheel steer. There was a video of him in reno on the strip.....I thought he was a member here...The reason I`m ask`n is I just saw it on e-bay. man that is a nice truck.John
http://cgi.ebay.com/ebaymotors/ws/eB...510572818&rd=1
71 chevy 4x4 ,np205 transfer case, 3 speed tranny, sjs 283, 4in suspension lift, and 71 hugger orange paint,33x12.5 parnelli jones on 15x10 m/t classicII, cowl hood,new bed painted, linex liner. Truck has been completed since 2005....
2003 Chevy Avalanche Z71, on 6in super lift w/ 35in tires
RNG4x4 aka the "Redneck Roller"
words to live by "If it fits, it fits"
"friends help you move, real friends help you move bodies..."
Sponsored by "Kick Ass Kustom"
bodazpa is offline   Reply With Quote
Old 12-13-2004, 02:54 AM   #2
4bynut
4bynut's Avatar
That's one awsome blazer.
4bynut is offline   Reply With Quote
Old 12-20-2004, 07:17 PM   #3
784X4GUY
Did someone say MUD?
784X4GUY's Avatar
Yeah that is one bad boy...
Im in the market guys...so keep ya eyes peeled
Mini trucks are for guys who cant get it up!
784X4GUY is offline   Reply With Quote
Old 12-20-2004, 07:26 PM   #4
Ifixyawata
Wonder how the rear steering is controlled? Maybe I should re-read the auction.
-Brian
'83 C10 305 -> 350
Ifixyawata is offline   Reply With Quote
Old 12-21-2004, 09:58 AM   #5
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
toggle switch controlles it.center postion locks it straight.up it turn the wheels one way,toggle down they turn the opposite direction.
I sat in that thing.It's cool watching is dogleg down the street.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 12-25-2004, 03:38 PM   #6
LKJR
that's 1fnhik5's truck over on ck5. I don't think he has been on in a LONG time but I remember him doing that rear steer conversion. You might try doing a search over there if you can w/o being a member. I know some of you are but a lot aren't but that is where he used to hang out a lot online.
1st Gen Blazers
Like em big and topless
LKJR is offline   Reply With Quote
Old 12-26-2004, 01:53 AM   #7
BobbyK
BobbyK's Avatar
I thought he sold it and bought a Jeep.
Old 12-26-2004, 02:11 PM   #8
LKJR
don't know, he hasn't been on in a long time. Just knew he hasn't posted there in a long time.
1st Gen Blazers
Old 12-26-2004, 02:39 PM   #9
full foot notch
by looking at it, it looks like he used a hydraulic ram, most likely tractor supply or northern tool, and it seems that its a dana 60 rear from what he said, and im guessing that he took the internals and knuckles and spindles from a front D60, put in the D60 internals, and flipped the knuckles and spindles from driver side to pass, and pass to driver side, so that the draglink and all is on the rear side, and pretty much he could not use a front axle in reverse due to the rotation of the wheels, so pretty much it looks like he made a reverse rotation front D60
thats my guess as to how he did it
full foot notch is offline   Reply With Quote
Old 12-26-2004, 07:25 PM   #10
LONGHAIR
I have never seen this truck in person, so I can't tell you how he did it...but I have done it. I can tell you that all you need is a normal front end. Chevy didn't do the reverse rotation thing like Furd did, so "technically" the front axle is wrong when it is in the front anyway. All you really have to to is move the rear springs inward to gain tire clearance when turned. It works well to move them in to the correct width of the existing perches of the front axle you use. Then you don't have to move/modify them at all. On all of the ones I did, I used a hydraulic cylinder that fit in the existing steering stabilizer bracket and tie-rod hole. It is also advisable to make a way to lock the rear wheels straight foreward and to electronically disable the hydraulic pump (key switch).
Using the stock parts is not only the simplest way but if you ever break an axle you can get a replacement quickly and easily. I did the conversion for a guy on a Blazer and he insisted upon centering the differential and having custom alxes made. It ended up costing him a lot more, but it turned out to be a "street queen", so he never had an axle problem as far as I know.
LONGHAIR is offline   Reply With Quote
Old 12-27-2004, 01:41 AM   #11
BobbyK
BobbyK's Avatar
You should see the locking pin.It's about an inch in diameter and is electrically activated.
