Old 07-10-2002, 01:47 AM   #1
Hooter
My other Love
Hooter's Avatar
Angry Motor wont turn! crap
Parked the truck in the driveway two days ago. went to start it the next day, starter turning real slow and smoking, so i switched starters, didnt fix the problem so then i took the spark plugs out and suddenly it turned over really easily. Then i put the plugs back in and tried starting it. Turned good for a couple of seconds now it wont turn anymore!.I cut my thumb real bad on the flex fan when my wrench slipped so now i am mad and there is blood everywhere. What do i do next?(btw it was running perfectly when i parked the ole 69 2 days ago)
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 07-10-2002, 03:26 AM   #2
damage
At first it sounds like the timing is way off... You said it was running fine couple days ago huh. With plugs out, motor is free to turn, but with plugs in, if the timing was off, it could be sparking before the cylinder is all the way up. I would start with timing and see where you stand from there. Distributor may have come loose and turned on you.
damage is offline   Reply With Quote
Old 07-10-2002, 04:43 AM   #3
Patrick Sullivan
Transcendental Trucker
Patrick Sullivan's Avatar
Yep, it sounds like your timing is way off. Mess with the distributor until you can get the thing to turn over..
Patrick Sullivan | sullivan@oregoncoast.com
Rockaway Beach, Oregon
1972 Chevy Cheyenne C-20
1998 Dodge Dakota 4x4
So, fill to me the parting glass
And drink a health whate'er befalls...
Then gently rise and softly call
Goodnight and joy be to you all!
Patrick Sullivan is offline   Reply With Quote
Old 07-10-2002, 07:11 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Thumbs up
1. put on a band-aid.
2. put battery charger on your vehicle's battery. If you have no charger, get another vehicle, and jump of yours with booster cables.
3. get rid of that flex fan, they are a liability. A blade can fly off, through your hood, and if anyone is in its way, it'll cot through them.
Old 07-10-2002, 08:08 AM   #5
racedvl
racedvl's Avatar
I agree with Andy 100%. Ditch that flex fan!!! Get your self a nice 6 or 7 blade clutch fan. It is( next to internal regulator convert.) one of the best swaps I did to my truck. Those flex fan just scare the sh*t out of me.. But that's my IMO.
racedvl is offline   Reply With Quote
Old 07-10-2002, 11:43 AM   #6
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Check your grounds....both on the battery and make sure you have a clean connection between the starter housing and the engine block
You might be getting just enough of a connection to start cranking, but when you get good compression, the voltage at the starter is too weak to finish the job.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 07-10-2002, 11:52 AM   #7
jku72
does sound like a voltage problem. Usual suspect is bad connections somewhere down the line, but things like the battery being old, or oil in the starter will slow things down.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 07-10-2002, 12:02 PM   #8
junkyardjohn
junkyardjohn's Avatar
Lightbulb
SORTA SOUNDS LIKE THE TIMING CHAIN JUMPED. FIND TDC ON #1 CYL, PULL YOUR CAP & SEE WHERE YOUR ROTOR IS POINTING. (SHOULD BE RIGHT AT #1)
SOMTIMES IT'S THE MOST OBVIOS THINGS.
(IF YOU HEAR HOOFBEATS, DON'T LOOK AROUND EXPECTING TO SEE ZEBRAS)
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 07-10-2002, 12:31 PM   #9
WB72
Before and After
WB72's Avatar
You could also check your timng chain, If it is in bad condition, it may have slipped a tooth. It happened to an 81 truck I had once. It took me forever to find the problem.
$0.02
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 07-10-2002, 02:22 PM   #10
junkyardjohn
YAH -- WHAT HE SAID --
junkyardjohn
DON'T RENT U-HAUL
Old 07-10-2002, 06:19 PM   #11
Randy70C-10
Randy70C-10's Avatar
Yeah, and get rid of the flex fan!!
Randy70C-10 is offline   Reply With Quote
Old 07-10-2002, 06:57 PM   #12
Patrick Sullivan
Man, no one likes flex fans, eh?
Mine hasn't given me any trouble.. of course, when I have the money, I'm going with an electric setup anyway.
Old 07-10-2002, 09:53 PM   #13
tom hand
CCRider
tom hand's Avatar
One more idea,[that you probaby don,t want to hear] You said the the motor turned over for a while after you put the plugs back in. That could be a headgasket leak filling one of the cylinders with water, causing hydralic lock. Just another thing to check.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 07-11-2002, 12:40 AM   #14
Hooter
My other Love
Hooter's Avatar
I did all the voltage block ground jumping (i even melted a set of jumper cables) still no good. Im thinking it could either be the timing chain or hydrolic lock. It is defenitly something mechanical. Now after the thumb severing incident i am going to invest in a nice carbon fiber fan from Lordco and pour some more vodka over the wound
pictures of my life
