#26 |
blood type; Retumbo
I just have to be the party pooper on this one.
maybe that is why the engine was just laying on the floor & no one wanted it. OK, that being said, I have the highest hopes for ya. SOMETHING good has to happen sooner or later
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
#27 | |
#28 |
its all about the +6 inches
The engien was being stored as a spare. I know the guy i bought it off of and trust him 100% He told me no knock no smoke...and that's what it was. I already racked up something like 70 or 80 miles on it yesterday, so this is a new problem, not something that was there when i bought it.
Don, would you bieleve me if i told you that I DID mention it? |
#29 |
blood type; Retumbo
OK, I'm sorry. I didnt know it was a spare.
then maybe a Caddy motor just has a problem residing in one of our trucks. should I stop my plans?
#30 |
LOL...well, 67-72king has a caddy in his longhorn, and he lost the oil pump goin down the road. He replaced the pump and all seemed good, but a couple days later it started knocking again.
Maybe it is just a longhorn thing. ![]() |
#31 |
Saving 1 truck at a time!
Andy, I have lost oil pressure and not had any problems with the motor. It sounds like you got it shut down soon enough. As long as the loss of pressure was not due to excessive bearing clearance you should be fine. I am sure you would have heard plenty of knocking it is was. You should pull the dizzy and try to pressurize it with the dizzy oil pump drive. Then you will know if the bearings are too worn to hold pressure.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
#32 | |
http://community.webshots.com/user/hotrodhorn |
#33 |
Good luck with it Andy. Just swap in the oil pump and fire it up it will either be a runner or you will know other wise pretty quick. I smoked a 305 one time and it ran O.K for a while but burned alot of oil. The bores got glazed from the heat. You will know it if it overheated real bad when you tear down the motor you will see alot of bluing on cylinder walls and bearings.
86 Silverado C10 back to 305 power! 67 C30 Dually Dump, with 350 transplant, Rockhauler 05 Duramax 3500 "If at first you don't succeed, try a bigger hammer" Member of the 1-Ton club! |
#34 |
72 Cheyenne
Sorry to hear Andy, I really hope things work out for you.
#35 |
Psycho-billy Member
Andy,
Sorry to hear about this. Make sure you get the correct pump to block gasket. Anything a little thinner or thicker will affect the oil pressure. The gasket that is made for is is all that will work correctly. Here's a thread about the gasket... http://www.cowboyseven.us/forum/index.php?topic=308.0
'72 C-10 350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers. Support your community, support yourself. Buy local, buy American ![]() |
#36 | |
![]() Your comment about 4Krpm just reminds me how different one truck can be from the next, mine with the 4 speed 700r4 and 3.08 gears won't never see 4K rpm on the interstate, at least, not in 4th gear (YOWZA) according to one of those calculators, 700r4 + 26.6 inch tire + 3.08 gears + .04 slip (??) = 141 mph, no way, in hell, is that happening, ever, heck even in 3rd that chart shows 99mph at 4000 rpm (ok that might happen but not very damn often!). |
#37 |
Yes, sure hope this won't be anything major for you Andy.... would like to hear its back on the road soon (instead of driving "plan B").
#38 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
![]() ![]() I wish you only the best and hope its nothing major, but for God's sake man, treat her like the old lady she is. ![]()
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#39 |
Man, that sucks! I remember buzzin' down the freeway When my old 402 decided it was time to retire. By the time I saw the smoke, it was too late, but it wasn't an oil pump. Good luck!
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
#40 | |
Resident Young Old Dude !
A bad bearing does stand out like a sore thumb !! It will either be worn/burned through to showing Copper, or just be Flattened and possibly Spun. If it's spun the bottom half and the upper half will be overlapping instead of Butting up to each other.. I've pulled them to where the bearing is actually over lapping the side of the rod cap.. ( Not a good thing) That was an engine I was pulling 9 Grand out of, and the oil pump shaft busted |
#41 |
![]() Join Date: Jan 2005
Good luck...
'72 Chevy K-20 Crate 350, SM465, 4.10's |
#42 |
...check your pm box andy...sent ya some info
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
#43 |
Andy,
put that oil pump on and try it. your due for some good luck. remember, the law of averages says that you can't have bad luck all the time. ![]()
i survived cancer and kidney stones, but my kids are killing me. |
#44 |
After reading this thread I'm glad the 425 with 400 tranny I bought is still resting in the 79 fleetwood out back! I started to put it in my GMC but when I got the 425 fired up it didn't sound too healthy so I went with a 350 4 bolt chevy. If you need any parts (hopefully not) give me a holler.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!! ![]() ![]() |
#45 |
update...I got 40PSI when i fired it up today.
![]() Lets see....questions and comments here... Lux..thanks, i knew that at one timne, but had completely slipped my mind. Now, if I were to mill my oil pump body...that would increase my oil pressure...would there be any reason NOT to do this? CPNE, you make a good point, however, I had just spun her up to 4000...I hadn't been holding it. I was trying to get in front of an old POS station wagon that was spewing oil and smoke from it's tail pipe. Kinda ironic in hindesight huh? And it wasn't my only mode of transportation...I'm hoildin onto the town car for this exact reason. Once the truck proves reliable, then I'll get rid of it. From what I understand, 4 k isn't all that hard on it...but 5k is askin for trouble. While yes, it was dormant for a long time...I have run it about 5 hrs all together over the last couple months, bringing it up to full operating temp, gone through about 5 or 6 oil chainges to flush out some contaminants (like fuel in the oil with the electric pump blowin it by the needles on the edelbrock) Then, on Sunday i drove her all over town all day. A couple short sprints on the freeway, but mostly just bumpin around on the surface streets. I looked at the odometer before leavin the shop today, and I drove it about 70 or so miles on sunday. So even though it had been dormant, I had run it a bit and it should've been good to go. |
#46 |
blood type; Retumbo
does it still run smooth? I have heard of engines sitting for a while wiping out the lobes after being brought back to life. one guy at work found this out the hard way with his HIGH dollar BB (over $8000)
#47 |
yep, ran smoothe, strong as an ox....made me want to drive it home...but it isn't leavin the lot untill i rebuild the oil pump and cut the oil fiolter open.
oh yeah, and drain the oil again too. |
#48 | |
Psycho-billy Member
It'd be best to leave it as is. I know guys that are running really stout 500+ inch Caddys with stock oil pumps. I don't really see any reason to try to get more on a stock engine.
#49 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
oil pump
Here Is a picture I found of an exploded view of an oil pump. I see yours is external. I'm not too familiar with caddys but this pic shows the pump IPB and the relief valve that you've been discussing . This is an AMC unit BTW.
VetteVet--hope shes ok
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
