Do I need a neutral safety switch?
I am just finishing installing my Van tilt. I went to hook up the netural safety switch and there are no wires to hook up to it
![]() Any help would be great. Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 04-07-2005 at 06:43 PM. |
![]() Join Date: Nov 2003
If you have an auto you will want the neutral safety switch. You may need to get a harness from an auto truck - but I am sure someone can tell you how to wire it into your existing harness.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Just find large purple wire from switch and cut. One side of cut to n. s. switch-the other side of cut to other side of n.s. switch.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
its all about the +6 inches
I bypassed mine too.
I know I ain't bumb enough to park it in drive, so that means it won't be in drive when I get in to start it. Right? |
