04-13-2005, 11:34 PM | #26 |
It's a catastrophic success.
Not real clear but it might help
04-13-2005, 11:52 PM | #27 |
On the road
It is for sure a small block top AC bracket, not nessecary but nice to have as it was stock. There is another adjuster on the front that will tension the belt without it. I have ran them with it and without, the pic is not too clear but this is my stock 72.
Mike
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
04-14-2005, 12:06 PM | #28 | |
graphic designer
04-14-2005, 01:45 PM | #29 |
AUSTIN TX
it looks to me that it goes underneath the hood.
04-14-2005, 03:01 PM | #30 |
Custom Builder
The engine was converted to a short water pump vice stock which was a long. Every bracket on the engine so far is for a Short Water Pump. I think I included some paperwork for you on a company that makes all the brackets you need to hang the stock A/C compressor. All the brackets you have with the compressor are wrong and will not line up to the pulleys that are on the engine. Take a look at the custom Power Steering brackets.
1932 Chevy Roadster Car and Pick-Up - http://67-72chevytrucks.com/vboard/s...d.php?t=465709 1966 K20 Factory 4X4 - http://67-72chevytrucks.com/vboard/s...d.php?t=455484 (Sold) 1972 K5 Blazer (Sold) - http://67-72chevytrucks.com/vboard/s...ad.php?t=87530 2007 TrailBlazer SS - http://67-72chevytrucks.com/vboard/s...34#post4706534 |
04-14-2005, 05:15 PM | #31 |
Fetzer Valve Technician
Here you go guys, All stock, never rebuilt:
1972 Chevy K10 SWB |
