Old 04-21-2005, 11:59 PM   #1
teamharvey
teamharvey's Avatar
Shifter question ?
I need to remove my 4X4 (transfer case) shifter to install my carpet correctly. This is all new and I don`t want to remove more than needed or mess something up.
thanks,
Bret
71 Custom 20 Deluxe..soon to be SWB 1/2 ton
1 incredible wife
2 great kids
teamharvey is offline   Reply With Quote
Old 04-22-2005, 11:11 AM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Why can't you cut the hole and put the carpet over the shifter? From my experience, you need the carpet out to remove/install the shifter because you have to remove the transmission/t-case hump.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-22-2005, 12:29 PM   #3
Yukon Jack
Yukon Jack's Avatar
I just did mine. Has to be easier to do from above so unbolt your hump and then there will be a bolt going through the shifter to a bracket and a bolt from the bottom of the shifter to the linkage. Remove both of those and you ought to be able to leave the bracket in place. Put the hump back on and make your cut. I cut the jute material with a box blade (carefully) it is a little hard to cut do to its thickness.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-22-2005, 07:29 PM   #4
teamharvey
teamharvey's Avatar
True, but pre-cutting the hole accurately with the shifter in place looks to be a challenge. I want to make sure all is in place and tight before cutting.
1 incredible wife
2 great kids
Old 04-22-2005, 07:38 PM   #5
bouncytruck
SKINNY TIRES RULE!
Yeah, I figured that out once Yukon Jack posted. Just because I look dumb, doesn't mean I'm not!
bouncytruck 1972 K5
Old 04-25-2005, 07:03 PM   #6
teamharvey
teamharvey's Avatar
Thanks ! worked just as you described.
Bret
1 incredible wife
2 great kids
