Old 06-11-2005, 01:47 PM   #1
rpm9100
wipers won't work
i have checked the fuse as well as the power wire, and they still don't work, what else other than a worn out motor could it be?
Aaron
rpm9100 is offline   Reply With Quote
Old 06-11-2005, 01:49 PM   #2
jhow66
jhow66's Avatar
Was they working and just stopped?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-11-2005, 01:59 PM   #3
rpm9100
no, I just got it.
Aaron
Old 06-12-2005, 12:05 AM   #4
jhow66
jhow66's Avatar
What model truck?
Old 06-12-2005, 12:17 AM   #5
71swb4x4
71swb4x4's Avatar
If you have power too them I would guess you hav a bad motor. It's fairly common to have those motors die. They really aren't tough to replace, just time consuming.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-13-2005, 11:04 AM   #6
farside847
farside847's Avatar
I have also seen the switch die. (mine)
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 06-13-2005, 06:11 PM   #7
Orange Truck
Orange Truck
Aaron
Check the switch mounted on dash. I had similar problem that was the switch.
Orange Truck is offline   Reply With Quote
Old 06-13-2005, 07:45 PM   #8
pissonNOS
senior member
pissonNOS's Avatar
i buy a new switch every spring so far ive gone thru 6 of them they work for a couple weeks then quit so now i have wipers but only when i push the button in for the sprayers
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 06-13-2005, 08:50 PM   #9
Jwill41
Jwill41's Avatar
I also have to hold the button in. I tried 3 used switches with the same results. Could they all be bad? If I reach under the dash and touch the right wire just right they work. I have replaced the plug and all wires look to be in great shape.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 06-15-2005, 01:29 AM   #10
rpm9100
Thank you for the replies, how would I check the switch?
Where is the wiper motor?
1970 Chevrolet C/10
Aaron
Old 06-15-2005, 01:49 AM   #11
knsmodels
I make Models
knsmodels's Avatar
Wiper motor is on the interior side of the firewall behind your dash.....if you look up under your dash you will see it. Not real easy to get to.
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
