Old 08-14-2002, 03:41 PM   #1
palallin
Rockwell Woes
Ok guys, the shop that has my truck has come up dry on a Rockwell T-case for my '69. He thought he had one bought, but it turned out the yard that had it had mis-identified the case. If anyone has one to sell, I have a WTB on the Parts and 4x4 Forums.
If none comes up for sale, is it possible to find the stuff needed to thoroughly rebuild one? The sliders are worn out, among other things, and some of the gears are chewed up.
How hard is it to swap in an NP205? Would I need more than the tranny-to-T-case adaptor and the driveshafts out of a later truck?
TIA.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 08-14-2002, 06:30 PM   #2
palallin
BTT
Old 08-14-2002, 09:34 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
What transmission do you have? If it was offered with the 205 you should be able to get a stock adapter and 205 and bolt it up. Not sure how it will effect your drive lines or if the tranny cross members are different. Also might need a new output shaft for the tranny. Around here(SE VA) in the local trading post there is always someone selling a 350/205 combo for around $400-500 even seen a SM465/205 combo for sell not too long ago.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-14-2002, 11:07 PM   #4
palallin
Good point: I have the SM 465.
Old 08-15-2002, 09:42 AM   #5
Yukon Jack
Yukon Jack's Avatar
There are rebuild kits available but I think they only contain seals, bearins and gaskets. Your gonna have a difficult time finding gears and other parts I think. Give Boyce Equipment & Parts Co. a call at 1-801-393-0007, www.boyceeequipment.com as they are the ones that priced me the rebuild kit a few months ago.
You might also call 4X Heaven at 1-800-800-1679, www.4xheaven.com
Lastly, e-mail member Gregsplace as seems like he might have a Rockwell sitting around for sale.
If it were me and I was faced with your problem, I would do my best to switch to the NP205. I'm keeping my Rockwell as I switch to a 4 speed, but just because it is working fine.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
