Old 09-17-2005, 09:27 PM   #1
bucket
bucket's Avatar
stiff windows
the years have not been kind to my window crank assembly. i have to pull up or push down on the window while cranking to get the things to move. does the assembly need to be pulled to fix or is it a lube thing. if lube, where should it go?
bucket is offline   Reply With Quote
Old 09-17-2005, 09:45 PM   #2
krue
Designated A-hole!
krue's Avatar
Check the channel your window moves up and down in, if it's in bad shape and is binding the window replacing that might cure it. Mostly tho it's wear and tear of the regulator itself. http://www.67-72chevytrucks.com/vboa....php3?t=157539 has a faq on replacing the regulator. You could use it to remove the door panel and visually check the regulator for wear or tear.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 09-18-2005, 01:57 AM   #3
69 Short Fleet
Great link Krue, as bucket mentioned what kind of lube is preferred? I suppose you could just use regular chassis grease. Doug
69 Short Fleet is offline   Reply With Quote
Old 09-18-2005, 04:44 AM   #4
krue
Designated A-hole!
krue's Avatar
I didn't lube mine, so I can't speak to it. I installed a new regulator on mine, bought it from GMCPaul and it works great now.
www.daveramsey.com
Old 09-18-2005, 02:56 PM   #5
bucket
bucket's Avatar
thanks for the link! i lubed it with a spray grease today while still in the door. it's a lot better but i probably need a new regulators. i will pull them when i paint.
