Old 10-10-2005, 05:35 PM   #1
71Chevystepside
oops shouldnt have cut this
I took the front springs out of my71 C10 454 combo wanting to lower them. I have drop spindles not installed yet and saw that the top of tire to fender edge was about 6 inches. So I thought cut 2 full coils out off from stock should be close. I was experimenting.
Oops lowered it to about 2 1/2 inches to top of tire and I dont have my drop spindles in yet and the front is real bouncy. And when I jack it up off the ground the springs come loose and fall out of place. So dont do what I did.
Just so I know next time. How much if any can a person cut off a stock spring to lower it without comprismising the spring and ride quality.
Thanks,
Rich
71Chevystepside is offline   Reply With Quote
Old 10-10-2005, 05:52 PM   #2
pissonNOS
senior member
pissonNOS's Avatar
one full coil
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 10-10-2005, 06:33 PM   #3
tnblazerk5
User #12137
tnblazerk5's Avatar
Originally Posted by pissonNOS
one full coil
yup thats what i did
tnblazerk5 is offline   Reply With Quote
Old 10-10-2005, 06:43 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Talking
In my old 70 we heated them all the way around until they touched coil
to coil like a slinky, had to cut all the snubbers out, but the truck looked
wicked, only bad thing is it road kinda like log wagon when you drove it.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-10-2005, 06:48 PM   #5
matthufham
i read 2 coils and my jaw dropped. 1 as you know by now is the limit.
matthufham is offline   Reply With Quote
Old 10-10-2005, 11:14 PM   #6
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I cut two coils and with the a 283 and stock spindles it is NOT low enough. Mine rides fine but I will still be going to spindles and bags to get it where I want it. If you want a set of stock small block springs, I have an extra set. With a big block on stock small block springs and spindles it may be low enough for you...all depends upon on how low you want it.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 10-10-2005, 11:20 PM   #7
llegos
how much does 1 coil get you? Can you do 1/2?
-Steve
llegos is offline   Reply With Quote
Old 10-10-2005, 11:40 PM   #8
68C15
blood type; Retumbo
68C15's Avatar
I dont suggest 1/2 coils. they need to sit in the pocket a certain way.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 10-11-2005, 03:23 AM   #9
71Chevystepside
stllookin,
Do you know if 6 cyl springs are the same as sb. I have a spare 67 c10 with stock springs. I am looking for 3 1/2 to 4 in drop in the front.
I have the 2 1/2 drop spindles what spring option would work best to get another 1 1/2 with a Big Block.
Also anyone know if 77 vintage springs fit our 67-72 trucks or are they different????
Old 10-11-2005, 04:46 PM   #10
tomatocity
tomatocity's Avatar
Originally Posted by 71Chevystepside
stllookin,
The 6-cylnder springs would raise a 58-64 Impala higher than the stock SB springs.
And DON"T cut half coils. Through experience, the top of the springs will move around and make popping noises with a 1.5 coil cut.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 10-11-2005, 05:55 PM   #11
boraxman
Keepin an eye out
boraxman's Avatar
Springs? We dont need no stinkin springs
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 10-11-2005, 06:29 PM   #12
stllookn
stllookn's Avatar
The six is heavier than the small block v-8 so they will probably raise it. Cutting one coil lowered me about 2 inches with my small block. boraxman...bags are much better and adjustable!
Old 10-12-2005, 07:04 AM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, you can use the 77 springs. They interchange.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
