Old 01-07-2006, 05:52 PM   #1
JRB
JRB's Avatar
Hydralic Clutch
I have a 1960 parts truck and it has a Master Cylinder with a port for the Brakes and a port for a Clutch Cylinder. Does anyone know where the clutch actuating cylinder mounts on the truck. I have been thing that this might be a work around for the V8 swap I am doing in my 63 shortwide. The problem I am having is the linkage for the clutch that is in it is right where the exhaust manifold dumps out. If anyone knows where the clutch cylinder mounts under the truck please let me know. Thanks in advance for any help you can give. Does anyone know if the Slave Cylinder that mounts to the Bell Housing On the 60 C10 is the same as the bell housing on the 63 with a manual clutch? Is this something that can be adapted to the 63?
Thanks,
JRB
56 Chevy 3100 BIGWINDOW Short Stepside
60 Chevy Apachee 10 Parts Truck
63 Chevy C10 Shortwide
64 Chevy C10 Shortwide
69 Chevy C10 Short Stepside
04 Chevy 2500HD Quad 4*4 Shortbed
02 Acura 3.2 TL Type-S (Wifes Car)
JRB is offline   Reply With Quote
Old 01-07-2006, 10:47 PM   #2
b454rat
Re: Hydralic Clutch
It's on the pass side, jsut above the starter.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 01-08-2006, 12:47 AM   #3
zenish
Re: Hydralic Clutch
it mounts to the bellhousing.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 01-09-2006, 09:59 AM   #4
60-66 Nut
Professional Beer Tester
Re: Hydralic Clutch
JRB, like was just said the slave cylinder mounts to the bell housing on the passenger side. There is no provision to mount the cyl on 63' up bell housings, except for big trucks that still used the hydraulic clutch. Hydraulic bell housings for the 235 six are easy to find, but they will not fit any other engine. A 60-62 hydraulic V8 bell housing would probably do what you want, but they are very hard to find. It would most likely be easier to find a left exaust manifold that dumps in the right place. There are several different manifolds for the small block V8(I assume that's what you're using, anyway) that will work with the mechanical clutch linkage. Just make sure the engine you use has the forward hole for the clutch pivot ball.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 01-09-2006, 11:58 AM   #5
JRB
JRB's Avatar
Re: Hydralic Clutch
The problem I am running into is the engine I have doesnt have the forward pivot hole. I have a set of ram horn manifolds for the motor that will reposition the exhaust. The thing is without that pivot hole I will have to fabricate a mounting plate for the clutch linkage that is in place now. I guess there is no easy work around on this. I just want to use this engine because I got it for free and it seems like a pretty tight 305. Thanks for the info.
JRB
