Old 01-12-2006, 04:01 AM   #1
355
355's Avatar
Startin up
In cold weather my truck likes to act like a new date that I don't understand. Usually I crank on it for about 5 sec two times then pull the choke and she will bust off, well thats most of the time. Recently I can crank on it with no start, but some times when I turn back the key to run and the engine is still rollin fast it will start. It's like the starter is pulling all of the juice and not leaving enough for the HEI to hit a good spark. Any help on this is appreciated. This has happened before over the years. Thanks Steve
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2.
355 is offline   Reply With Quote
Old 01-12-2006, 04:46 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: Startin up
ignition switch?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 01-12-2006, 05:02 AM   #3
355
355's Avatar
Re: Startin up
I might need to add that after the babe has started and warmed up it will bust off everytime, in a normal sort of way.
Old 01-12-2006, 08:48 PM   #4
krue
Designated A-hole!
krue's Avatar
Re: Startin up
What do you do with the gas pedal? My choke isn't hooked up and I pat the gas a couple of times, then hold the pedal to the floor and mine cranks right up. BTW folks when he says cold weather, he means cold for MS (around freezing).
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
