02-20-2006, 03:57 PM | #1 |
GM ONLY BABY!!!
Who makes drop leaf springs for 72 GMC 1500?
I have a 72 GMC 1500 and am needing to install some drop leafs in the rear. Who makes or sells them besides ECE. I am not sure if I need a 5" drop like they sell. I might only want to do a 3" or 4".
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
02-20-2006, 05:17 PM | #2 |
Got trucks?
Re: Who makes drop leaf springs for 72 GMC 1500?
As I recall there are a couple of ways of getting a smaller drop, one is to put the drive axle on top of the rear leafs (the flip kit), hte other is to take the leafs to a reputable spring shop and ask them to de-arch them. Personally I recommend looking into the flip kit, since de-arching the springs has been known to change spring rates, and I am assuming you want to keep the same spring rates, otherwise removing leafs is another way to get a slight drop in the rear end.
Emerald OOGLY 68 1/2 ton LWB with 250 6-banger and TH350 (soon to be 350 with TH400) |
02-20-2006, 05:20 PM | #3 |
Axel flip will give you 6"drop. ECE and Classic Performance have drop springs.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-20-2006, 10:41 PM | #4 |
8 vehicles only 4 that run
you could get the 5" drop springs, and then get some 2" lift blocks to put between the leafs and the axle, giving you an effective 3" drop. Advance has the lift blocks for like $20-30.
95 2500 350 w/ 3.73 72 GMC 1500 SWB stepside 65 Chevy C10 SWB stepside 72 Chevy C10 LWB fleetside |
