60-66 4x4 steering
Hey can someone post some pics of there 60-66 4x4 steeering by the drivers side, mine does'nt look right to me. Just want to make im riding around safely. Thanks Jeremy
Re: 60-66 4x4 steering
posting a pic of yours might help as well...they are really pretty easy..
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
Are you still running a closed Knuckle front axle?
Yes I am,what doesnt look right is the, I guess its called the draglink from the pitman arm to the arm on the knuckle. I have a LMC truck mag that shows the part and mine doesnt even come close to looking like it, and of course this part is not available. OK got my assembly manual out and they call the part a connecting rod assembly. I guess I could use two tie rod ends and a connector? Let me know Jeremy
awaiting pics...
I'll have pics for you when I get home after work today. Thanks
It’s the draglink I'm trying to figure out. Obviously its not the stock one, somebody rigged this one up. My pitman arm has a threaded 3/4 hole and the steering arm also has a 3/4 hole. So my question is do they make tie-rod ends to fit that size hole? I know I will have to taper the steering arm and the pitman arm for the taper on the tie-rod. Here is a picture of what I have now. Thanks.
Jeremy |
I guess the heim joints will work for a draglink?
I just threw one of those away last month from a 69... dang it! I'll look around and see what I can find. Are you wanting to replace your drag link back to stock? It looks solid from the pic but.... lives are riding on the quality of work, yours included.
I asked around on some 4x4 boards and there saying its stronger or just as strong as the tie rod made draglinks. So I ordered some new parts to rebuild it. Thanks Jeremy
