Old 06-17-2006, 09:33 PM   #1
truckdude239
truckdude239's Avatar
no fire no start
okay got a timing light this morning and timed my truck its sweet spot seemed to be 9 dregees btdc run good no pinging or nothing let it sit ilding it cut off now i have no fire from the coil replaced the coil and condenser still no fire got points and going to get a set of wires to make sure that the coil wire isn't bad any other things i need to look at and get it running again
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-17-2006, 11:34 PM   #2
QKENUF4U
QKENUF4U's Avatar
Re: no fire no start
make sure ya still have power TO the dist.
QKENUF4U is offline   Reply With Quote
Old 06-18-2006, 12:41 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
With the key on you should have about nine volts to the + side of the coil and while the starter is turning you should have 12 volts. The - side of the coil is connected to the points and condenser and ground when the points are closed and when they open the coil fires. You can run a jumper to the + side of the coil and see if it cranks the engine but don't leave it on or it will burn up the coil.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-18-2006, 12:56 AM   #4
89 crew
check the resistor. and if it is good make sure you are not running an internally resisted coil!
89 crew is offline   Reply With Quote
Old 06-18-2006, 03:12 PM   #5
71chevytruckguy
71chevytruckguy's Avatar
check your points, could be adjusted too far out and not be closed enough to get fire. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
