Old 06-26-2006, 01:19 AM   #1
cell
Active Member
cell's Avatar
options for 3.08 gears?
So, if I want 3.08 gears to put in my rear end, what are my options? Does anyone make aftermarket gears, or am I stuck finding something used which hopefully isn't too worn?
cell is offline   Reply With Quote
Old 06-26-2006, 08:42 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: options for 3.08 gears?
You can buy Richmond gears from Summit Racing or Jegs. It's pretty hard to beat their prices these days...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-26-2006, 11:45 PM   #3
cell
Active Member
cell's Avatar
wow, that is cheap. now I just need to figure out if I have a series 3 or series 4 carrier.
but I don't really need to worry about this for about another month or two. getting the engine back in the truck would be slightly more important
Old 06-26-2006, 11:47 PM   #4
cell
Active Member
cell's Avatar
hmm, that makes me think. Should I get a 3.08 gear set and a newer 5 speed manual with overdrive, or should I try and get a 2.56 gear set and keep my original SM465 4 speed with top gear at 1:1?
hmm...
Old 06-27-2006, 05:04 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'd go with the 2.56. There isn't a 5 speed with overdrive that i know of that is strong enough to hold up bolted to a strong engine and last very long. (very long defined as 100k)
Old 06-27-2006, 12:56 PM   #6
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
i just went through this, and ended up getting a whole rearend w/3.08's
tommie is offline   Reply With Quote
Old 06-27-2006, 02:58 PM   #7
smoknbarrels
Registered Mail
smoknbarrels's Avatar
I have been having similar issues, I am installing a 5 speed with a nice 0.64 overdrive so you can still run low gears. the tranny i am using is a tremec TKO 600 rated for 600 lbs of torque i hear nothing but good things about it, but i also have a similar problem about the rear end...
how do I know what posi carrier i have? I have a used posi unit but I don't know if it is for a 3.42 and up ring gear or a 3.42 and down ring gear??
smoknbarrels is offline   Reply With Quote
