Old 09-25-2006, 08:42 AM   #1
straight axle
straight axle's Avatar
heater core
I need to put a new heater core in my 84 pickup. I have not taken the time to look real close yet, does the heate core come out from the engine bay side or the cab side????
Jon
straight axle is offline   Reply With Quote
Old 09-25-2006, 09:07 AM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: heater core
I have never tried it, but here are some instructions that others here have said were helpful.
http://coloradok5.com/heatercore.shtml
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 09-25-2006, 09:27 AM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Re: heater core
The core comes out the passenger side of the cab, BUT the bolts and nuts are in the engine bay. The housing will have to have the heater controls removed from it, which is easy once you remove the glove box from the dash. The heater core is mounted into the interior housing and after you remove the housing from the cab, there are a few small bolts and clamps that hold it in place. Use this opportunity to lube all of your lheater doors and fittings, also.
Old 09-25-2006, 03:32 PM   #4
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Re: heater core
Some have had to remove the inner fender to reach one of the bolts, like the article describes. But, with a long extension and an uinversal joint, I was able to access the nut without removing the inner fender. BTW, watch out for any coolant left in the heater core.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 09-26-2006, 05:44 AM   #5
straight axle
Re: heater core
Thanks guys. I will get on it this weekend
