Old 10-28-2006, 07:36 PM   #1
Ludington1
Headlights stopped working... help?
Got in my 70 Blazer last night to go for a quick cruise, and the headlights won't turn on. All the side marker lights come on, tail lights, and the marker lights in the grille work... just no headlights.
Anyone have this happen before or have any ideas on where to start troubleshooting? Is there a fuse that does just the headlights?
Thanks in advance,
Darren
Ludington1 is offline   Reply With Quote
Old 10-28-2006, 07:42 PM   #2
SNEAKYPETE
Re: Headlights stopped working... help?
check your floor dimmer switch
SNEAKYPETE is offline   Reply With Quote
Old 10-28-2006, 07:45 PM   #3
Ludington1
As in check the floor switch wiring or is there a way to test it for function?
Thanks again!
Old 10-28-2006, 07:49 PM   #4
krue
Designated A-hole!
krue's Avatar
Try dimming the lights and see if they come on. If you're truck is like mine you may need to make sure the wires are connected to it.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 10-29-2006, 08:04 AM   #5
vtblazer
vtblazer's Avatar
Try all above, plus checking for connection at the headlights themselves.
(wiggle the wires)
Couls also be in the headlight switch on your dash.
vtblazer is offline   Reply With Quote
Old 10-29-2006, 01:29 PM   #6
Gillnetter
Gillnetter's Avatar
Could be two burnt out headlights?Icouldn't get high beams to work both bulbs were burnt out. Easy fix once I figured it out.
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash
1972 SWB C-10 Highlander Blue/White
1972 Canadian 2wd Jimmy light olive
1970 SWB 4x4 4 speed 307
Gillnetter is offline   Reply With Quote
Old 10-29-2006, 01:50 PM   #7
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I've had two trucks melt the brown headlight wire under the dash. Take a look and see if it is ok (probably is because I think all the lights go out when it goes bad.)
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 10-29-2006, 02:13 PM   #8
Ludington1
Ok... the dimmer switch plug wasn't connected. Don't know how it happened, as I've been driving the truck for a few months and the lights have been working fine. Anyway... thanks for all the help!
Darren
