Old 11-28-2006, 03:15 PM   #1
cheyenne10
cheyenne10's Avatar
Best PS box for 72 4x4
What do you guys/gals recommend for new steering box for 72 4x4? Prefered supplier?
Thanks.
Bob
cheyenne10 is offline   Reply With Quote
Old 11-29-2006, 06:16 AM   #2
Mudder
Mudder's Avatar
Re: Best PS box for 72 4x4
I have gotten the last couple from the local parts stores. If I remember right they were around 70 bucks and were rebuilt.
Mudder is offline   Reply With Quote
Old 11-29-2006, 11:53 AM   #3
Livrat
Member #1049
Livrat's Avatar
RedHead Steering Gears, 900 N. 127th, Seattle, WA. (206) 364-3333
I've had one of theirs in my truck for over 20 years and its still going strong
Livrat is offline   Reply With Quote
Old 11-29-2006, 12:51 PM   #4
cheyenne10
cheyenne10's Avatar
Does adding new steering box tighten up handling on our older trucks? I know it depends on how worn old one is and how suspension, etc. is on truck but most of these 30+ year old boxes seem to be a little loose.
I was also hoping to hear any pros/cons to newer variable ratio boxes or ones with different ratios. Part of me assumes it would not matter but I was hoping for a tighter turning radius on 72 swb 4x4. Had a Ford recently that was same length but seemed to get quite a bit better turn around. I was thinking it was due to quickness of my response rather than geometery of truck.
Bob
Old 11-29-2006, 01:14 PM   #5
Mudder
Mudder's Avatar
I found that too much air in the front tires will make mine terrible. There are newer aftermarket boxes out there but are quite pricey.
Old 11-29-2006, 10:08 PM   #6
skchevota
skchevota's Avatar
I am running one from a 79 and it works great, however I was using a 2wd box with a cross over steering link and it had a mmmmuch tighter turning radius
skchevota is offline   Reply With Quote
