Old 12-13-2006, 03:35 PM   #1
JMac11
JMac11's Avatar
Backspacing 20" Wheels
Found some 20's I can stand. Similar to what Dave johnson has on his Black Jimmy. They come with 5" Back Spacing. Will the extra rim size help the clearance issue? Can get them for a steal, just not close enough to check for fit.
JMac11 is offline   Reply With Quote
Old 12-13-2006, 06:10 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Backspacing 20" Wheels
Depends on the tire size
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-13-2006, 06:33 PM   #3
JMac11
JMac11's Avatar
They should fit the wheel well. 33x12.50's. I thought there was a steering clearaance issue??
Old 12-13-2006, 06:59 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Might be, how much lift do you have again?
Old 12-13-2006, 09:06 PM   #5
JMac11
JMac11's Avatar
ok.... here goes:
Truck is supposed to have a 4" lift. The distance from the factory bumb stop and the spring retainer on the front axle is > 5".
Existing setup is 285/r70/16 on what appears to be 16"x8" with 4" back spacing
The only thing close to the wheel is the tie rod end and it is CLOSE, but it would be 3 or more inches inside a 20" rim and the distance should remain constant unless catastrophic failure were to occur.
Old 12-13-2006, 10:47 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Sounds like it will work, can you test fit them before you buy em?
Old 12-14-2006, 07:28 AM   #7
JMac11
JMac11's Avatar
nope, great thing about Ebay, ain't it....... Gotta be a riverboat gambler, sometimes.
Old 12-14-2006, 11:16 AM   #8
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I would not even try 5 inches. You couldn't do a u-turn in a mall parking lot.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 12-14-2006, 11:51 AM   #9
JMac11
JMac11's Avatar
?? Lost me there? CLearance or Steering Geometry issue?
Old 12-15-2006, 12:52 AM   #10
2wdBlazer
The Blazer King
2wdBlazer's Avatar
you are putting the tire too close. i was being sarcastic, you may be able to turn but definate rubbage.
Old 12-15-2006, 12:40 PM   #11
70rs/ss
70rs/ss's Avatar
The back space issue comes from interferance with the ball joint, but he is talking 20's so it will place the tire/wheel far from the tierod. Most of these trucks like 3.5-4" of backspace, if nothing else steal em on ebay, try em and if they do not fit re-ebay them or just get a 1" spacer to put the wheel at 4" of backspace. Billet spacers are way strong and an inch is not an issue (2" and up I'd be concerned) Good Luck!!
70rs/ss is offline   Reply With Quote
